3rd Gen Durango 2011+ models
right turn signal blinks fast after trailer wiring
Old 03-18-2017, 12:50 PM
DRDIESEL's Avatar
DRDIESEL
DRDIESEL is offline
Default right turn signal blinks fast after trailer wiring
install curt manufacturing trailer wiring. Had multiple issures with turn signals not working lights not working and lights coming on by themselves. replaced the unit under warranty. Same bull garbage.
Install Dodge Durango wiring and reprogram for trailer lights installed.
Right rear turn signal fault on dash. (Right rear turn is out). Dash indicator and turn signal in mirror blink fast.
The rear and front turn signal blink correctly. NO BULBS ARE BURNED OUT. swapped the rear left and right turn signals and the problem still exists.
Anyone have the same issue and a fix?
It driving me bananas
Old 03-19-2017, 10:37 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
Did the installation of the Curt wiring require you to splice in to any wires or was it intended to be plug and play?
-Rod
Old 03-20-2017, 07:07 AM
DRDIESEL's Avatar
DRDIESEL
DRDIESEL is offline
Default Curt
the curt is a plug and play .. Plugs in tail light harness .. Have to run battery power to it.
