3rd Gen Durango 2011+ models
Rear break lights & turn signal not functioning
Old 03-22-2017, 09:31 PM
Jay Paz-Cage's Avatar
Jay Paz-Cage
Jay Paz-Cage is offline
Default Rear break lights & turn signal not functioning
I'm have an issue with my rear break lights and turn signals. I replace all of the bulbs. Every bulb in the rear lights up when I turn the lights on however I can not get the turn signal or break lights work. The fronts turn signal functions fine.. also my center break like works as well. What could be the issue because not of the fuses are blown and everything is lit??! Help a brotha out!! Seems like it will end up costing.
Old 03-23-2017, 07:37 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
you need a volt meter and to start testing wire connectors, there is an open circuit somewhere. The fact that the third brakelight is working makes me think there is nothing wrong with the control circuits/computers.
Old 03-28-2017, 05:10 PM
bearclaw's Avatar
bearclaw
bearclaw is offline
Yep, get a $10 multimeter and start testing connections. Open circuit somewhere.
