View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
- Dodge Ram 2002-2008: The Ultimate Air Intake Guide
Review of top products and step by step instructions
Cold air intakes
#101
I am thinking of making a DIY CAI. Are there any problems with these setups with the pipe melting or softening up on hot days? What type of piping did you guys use?
#102
Pvc is rated for 180 degrees I have not nor have I heard of any problems with melting, Use 3inch pvc 1ft straight one 45 degree and one 90 degree elbow Your gonna need a small beather filter for the left side oil return. Also a couple to attach the elbow to the tb. That can be found in the same aisle as the pvc .Use reg pvc cement with a spectre filter peoiled so you can address it a year later that filter just gets cleaned and re oiled w/ a kit that spectre sells. check out my profile page for a picture. good luck and take your time.
#103
Do the dual filter CAIs do that much better? I would think so but then again, only so much air can go in or else people would be running setups with 4 filters, etc.
I've seen the home brewed 4" intakes that people make out of PVC pipe. Do the 4" do that much more than a 3"?
I searched but couldn't find these answers.
#109
Does anyone have real numbers to back up performance gains with different CAI's? I fear that some of the performance gain is merely imagined because of the difference in engine sound etc. Thanks for any real numbers!
#110
Still enjoy the sound: as of 4may10
Got 6.71 after K&N 57 Intake vs 7.11 w/ only S/C 3865 91 tuned 6200 1&2 wot shift.
No other mods just intake and flashpaq. 5may10
