View Poll Results: What brand of lift kit do you have?
ProComp
13
11.02%
Fabtech
26
22.03%
Rancho
21
17.80%
Revtek
1
0.85%
Rize
1
0.85%
Skyjacker
9
7.63%
Superlift
4
3.39%
Trailmaster
3
2.54%
Other(post in your reply)
40
33.90%
Voters: 118. You may not vote on this poll
Lift kits-Suspension
Old 04-12-2009, 12:18 AM
santafehemi's Avatar
santafehemi
santafehemi is offline
just had the fabtech installed and i am satisfied with it so far.
Old 07-19-2009, 03:16 PM
hemipower05's Avatar
hemipower05
hemipower05 is offline
so i have an awd 2005 ram 1500... i want a 6 or 5.5 inch lift preferably from fabtech... i saw one lift kit from them that i wanted but it said it didnt fit if you have the awd option.... anyone with an awd have a 6 or 5.5 inch lift?
Old 07-25-2009, 03:47 AM
Hendogg's Avatar
Hendogg
Hendogg is offline
Well for all of you that want to go VERY VERY BIG look at Whiplash Suspension they have 94-02 Dodge Ram 1/2 & 3/4 to 10in & 12in lift. And for yall that have 03-08 Dodge 3/4 ton they have 10in & 12in as well.. And for yall that have 02-05 1/2 ton trucks they have a 10in & a 14in lift... And Full Throttle Suspension has 03-08 Dodge Ram 2500&3500 5in & 6in & 10in lifts.. And for the 99-07 Dodge ram 1500 they have a 5in & 10in & 14in lifts as well.... And Extreme Articulation has 6,10,12,14 in lift kits And the guy at Extreme Articulation Drives a BAD TO THE BONE 2001 dodge ram 1500 with a 14" coil springs up front and 14" leafs in back and a set of 44 in Bogger's There are Pic's of it in the Gallery and it is black.. I hop that this help yall out a little bit.. I am running 12 lift and a 3 in body lift and 40x15.50x16.5 on a 1977 dodge 1 ton 4 door 4x4 Short bed.. And the guys at all 3 shops will help you out a lot and they can make just about any Custom lift that you want.. All it cost's is $$$$....
Old 08-03-2009, 08:43 AM
SMKNRAM's Avatar
SMKNRAM
SMKNRAM is offline
rough country leveling keys
Old 09-30-2009, 02:11 AM
thatboy_rob's Avatar
thatboy_rob
thatboy_rob is offline
I have a mix-pieced kit. My front consists of a 4" CST spindle and a 1.5" Daystar spacer with ProComp ES9000 shocks. The Rear is a 2" rear block from Rough Country with the same shocks. All in all it gives me a pretty decent ride compared to stock and a good lift to boot, enough to clear 20s with 33s and I'm told 35s so might go with those pretty soon. Probably also going to swap out the stock coil spring for CSTs 3" spacer and add-a-leaf in the rear and a 2" body lift for a total of 9" of lift.
Old 10-01-2009, 05:29 PM
Jwise's Avatar
Jwise
Jwise is offline
Voted fabtech not sure if its the best but heard good things so far and leaning towards getting one.
Old 10-01-2009, 08:42 PM
AlbertaRAM's Avatar
AlbertaRAM
AlbertaRAM is offline
Does Skyjacker even make a kit for an '06 1500?? Nothing listed on their website... the 1500 isn't even a choice from the product menu for 2006 haha
Old 10-13-2009, 06:44 PM
AsphaltCowboy's Avatar
AsphaltCowboy
AsphaltCowboy is offline
ok, another newbie here. lookin to fit 35's on my 08 1500 4x4 QC. will a rough country 2.5" leveling kit do to job or do i need a mild lift? any recommendations?
Old 10-14-2009, 06:54 PM
rydesolow's Avatar
rydesolow
rydesolow is offline
Right now on my 02 I have a 6" fabtech and 3" PA body lift. The fabtech is incredible. All the geometries of the suspension have been set perfectly. There is no strain on any components. The drop brackets for the front diff lower it enough so my output shafts are exactly straight, no upward or downward angle. The rack and pinion is dropped also, so there is no angle in steering. The dif is also angled toward the t-case, and a spacer is provided for the bolt on for the drive-shaft to connect to. No vibrations at all, at any speeds-and I've gone about 100mph so far without a problem. All the sway-bar links pivot, and the entire sway-bar is lowered on brackets to maintain factory ride. Overall, the kit is incredible. It is made very well. I couldn't of asked for more. I believe just a 6" fabtech will stuff 35-36" tires, with my 6" fabtech and 3" PA I can fit 38"'s easily with plenty of bump room.
Old 01-24-2010, 12:52 AM
LanceFuson's Avatar
LanceFuson
LanceFuson is offline
Hey guys Does any one know if I can fit 315/70/17 on my 07 megacab 1500 without a lift?
Quick Reply: Lift kits-Suspension
