View Poll Results: What is the diameter of your tires?
Stock (up to 33" depending on wheel)
337
75.22%
35"
95
21.21%
36"
0
0%
37"
11
2.46%
38" or greater
5
1.12%
Voters: 448. You may not vote on this poll
Tires (size and fitment)
#21
I hope this is the right place for this. I want to run 33x12.50r20s. I know that in 2007 the federal government made a law that requires manufactures to instal Tire Pressure Monitoring sensors on the vehicles the produce. so i want to know if i put new bands and sensors on my 33's if there is a way i can reprogram the computer so the light will stay off and work properly with what ever pressure i set my tires to. Any info would be great thank you.
#22
I got my Mud Grapplers installed last night. I ordered 33's and they ordered 35's by mistake. I decided to try them on anyway, and they fit. I'm running stock wheels, no spacers, and no leveling or lift kit. I do have the torsion bars cranked up a bit, but not quite enough to level the front. The tires barely rub the sway bar on the inside side biters, but only when turned to full lock. I'm sure a set of leveling keys would correct this. They look awesome though...they fill the wheel wells nicely.
OMG I FELL IN LOVE INSTANTLY!!!!!!!! I only hope my Truck will look that good when i get my 35s!!
#23
so my stock tires are starting to cup. im gona need to replace them. can i roll 35x12.50x20's on my 2008 4x4 with stock rims and a leveling kit? im gona have to buy one at a time since they're so damn expensive.
#24
I just put 35 x 13.5 Mickey Thompson's on 20" rims. I have a 2" levelling kit and am getting a little bit of rubbing at full turn. I'm doing a little "trim job" on it this week and it should be okay.
#28
i dont know much about the metric sizes, but im looking at a set of BFG AT/KO's for my 08 with a leveling kit on the front. would a 285/65R20 fit ok? its 34.58" tall and 11.22" wide. stock tires are 33" tall and 10.82" wide. would i rub at all with the bigger tires?
#29
newbee here in need of help
Hello All
I have a 2006 Ram 2500 Diesel 4x4. I am looking a putting 20" rims on the truck. I have found, at Centerline...
Part number 654 2858 865
I want to put BFG All Terrains on the above Wheels...LT285/65R20/E.
Will these fit correctly with the offset and the size on a stock (non lifted) 2006 Ram 2500 4x4?
I have not bought them yet, but i need some advice first.
Thanks
Russ
20.0 x 8.5 chrome forged wheel
6.0" Backspace
Dodge Truck 8-lug (03-newer). This is an excellent fit for the new hi-positive offset Dodge Trucks. Wheels are 32mm positive offset and will tuck nicely inside fenders..
8-6.5" Bolt Circle
6.0" Backspace
8-6.5" Bolt Circle
Thanks
Russ
#30
just wanna let people know that a 315/70/17 equals about a 34.5'' tire will fit on a my 2005 ram 2500 with no lift only rub a bit at fullturn. But bf goodrich makes a 305/65/17 i was told will not
