---------->3rd Gen Ram SERVICE & MAINTENANCE FLUID Specs! <------------
Old 06-23-2012, 09:05 AM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
Default ---------->3rd Gen Ram SERVICE & MAINTENANCE FLUID Specs! <------------
I copied these straight from PDF Owners Manuls so they are not charts like the PDF file. I did what i could to straighten them out for all.
Engine Oil (with filter)
3.7L Engine V-6 (SAE 5W-20, API Certified) 5.0 qts 4.7 L
4.7L Engine V-8 (SAE 5W-20, API Certified) 6.0 qts 5.7 L
5.7L Engine V-8 (SAE 5W-20, API Certified). For trucks operating under a gross combined weight rating less than 14,000 lbs. 7.0 qts 6.6 L
5.7L Engine V-8 (SAE 5W-30, API Certified). For 2500/3500 trucks operating under a gross combined weight rating greater than 14,000 lbs. 7.0 qts 6.6L
Cooling System
3.7L (MoparAntifreeze/Coolant 5 Year/100,000 Mile Formula) or equivalent. 17 qts 16 L
4.7L (MopraAntifreeze/Coolant 5 Year/100,000 Mile Formula)or equivalent. 17 qts 16 L
5.7L (Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula)or equivalent. 18.7 qts 17.7 L
FLUIDS, LUBRICANTS AND GENUINE PARTS
Engine Coolant Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology).
Engine Oil (3.7/4.7L Engine) Use SAE 5W-20, API Certified, meeting material standard MS 6395.
5.7L Engine Oil (For trucks operating under a gross combined weight rating less than 14,000 lbs/(6,350 kg.) Use SAE 5W-20, API Certified, meeting material standard MS-6395.
5.7L Engine Oil (For 2500/3500 trucks operating under a gross combined weight rating greater than 14,000 lbs/(6,350 kg.)Use SAE 5W-30, API Certified, meeting material standard MS-6395.
Engine Oil Filter (3.7L Engine) Mopar Engine Oil Filter, P/N 4781452BB or equivalent.
Engine Oil Filter (4.7L & 5.7L Engine) Mopar Engine Oil Filter, P/N 4884899AB or equivalent.
Spark Plugs (5.7L Engine) REC14MCC4 (Gap 0.043 in [1.09 mm])
Spark Plugs (4.7L Engine) Upper Bank — FR8TE2 (Gap 0.039 in [.99 mm]) Lower Bank FR8T1332(Gap 0.051 in [1.30 mm])
Spark Plugs (3.7L Engine) ZFR6F-11G (Gap 0.043 in [1.09 mm])
Fuel Selection (3.7L/4.7L Engine) 87 Octane
Fuel Selection (5.7L Engine) 87 Octane Acceptable - 89 Octane Recommended
Chassis
Automatic Transmission MoparATF+4, Automatic Transmission Fluid.
Transfer Case Mopar ATF+4, Automatic Transmission Fluid.
NVG 246 Automatic Transfer Case Only Mopar PN 05179014AA, NVG 246 Automatic Transmission Fluid or equivalent.
Manual Transmission Fluid (G238) Mopar ATF+4, Automatic Transmission Fluid.
Manual Transmission Fluid (G-56) Mopar ATF+4, Automatic Transmission Fluid.
MAINTAINING YOUR VEHICLE 511
Clutch Linkage Multipurpose Grease, NLGI Grade 2 E.P. or equivalent.
1500 Model Front Axle (4X4) GL-5 SAE 75W-90 (MS-9763) or equivalent.
1500 Model Rear Axle Mopar Synthetic Gear Lubricant SAE 75W-140 (MS-8985). Limited-Slip Rear Axles on 1500 Models Require the addition of 118 ml (4 oz.) Mopar Limited Slip Additive or equivalent.
2500/3500 Model Front and Rear Axle Synthetic, GL-5 SAE, 75W-90 or equivalent.
Limited-Slip 10.5/11.5 inch Rear Axles Limited slip additive is not required.
Brake Master Cylinder Mopar DOT 3 and SAE J1703 should be used or equivalent. If DOT 3 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids.
Power Steering Reservoir Mopar ATF+4, Automatic Transmission Fluid.
Perform Maintenance Every
(Where time and mileage are listed, follow the interval that occurs first.)
Maintenance Items, Miles/ Kilometers or Months
Change the engine oil and engine oil filter. 6,000mi/ 10 000kmi or 6mo
Rotate Tires. 6,000mi /10 000kmi or 6mo
Lubricate outer tie rod ends 2500/3500 (4X4) models only. 6,000mi /10 000kmi or 6mo
Lube Front Drive Shaft Fitting (2500/3500, 4x4 only). 6,000mi /10 000kmi or 6mo
If using your vehicle for any of the following: Dusty or off-road conditions. Inspect the engine air cleaner filter, replace if necessary. 12,000mi /20 000kmi /12mo
Inspect the brake linings, replace if necessary. 12,000mi /20 000kmi or 12mo
Inspect the front & rear axle fluid, change if using your vehicle for police, taxi, fleet, off-road or frequent trailer towing. 18,000mi /30 000kmi /18mo
Inspect the CV Joints. Perform the first inspection at 12,000 miles (20 000 km) or 12 months. 24,000mi /40 000kmi or 24mo
Inspect Exhaust System. Perform the first inspection at 12,000 miles (20 000 km) or 12 months. 24,000mi/ 40 000kmi or 24mo
Inspect the front suspension, tie rod ends and boot seals, replace if necessary. 24,000mi /40 000kmi or 24mo
Replace the engine air cleaner filter. 30,000mi /50 000kmi /30mo
Inspect the transfer case fluid. 30,000mi /50 000kmi or 30mo
Replace the top row of spark plugs on 4.7L engines. ** 30,000mi /50 000kmi or 30mo
Replace the spark plugs on 3.7L and 5.7L engines. 30,000mi /50 000kmi or 30mo
Change the automatic transmission fluid & filter if using your vehicle for any of the following: police, taxi, fleet or frequent trailer towing. 60,000mi /100 000/kmi or 60mo
Change the transfer case fluid if using your vehicle for any of the following: police, taxi, fleet, off-road or frequent trailer towing. 60,000mi /100 000kmi or 60mo
Change the manual transmission fluid if using your vehicle for any of the following: trailer towing, snowplowing, heavy loading, taxi, police, delivery service (commercial service), off-road, desert operation or more then 50% of your driving is at sustained high speeds during hot weather, above 90F° (32C°). 60,000mi /100 000kmi or 60mo
Inspect and replace PCV valve if necessary. 90,000mi /150 000kmi or 90mo
Flush and replace the engine coolant. 102,000mi/ 170 000kmi or 60mo
Replace the ignition cables on 4.7L engines. 102,000mi /170 000kmi or 102mo
Replace the side row of spark plugs on 4.7L engines. ** 102,000mi /170 000kmi or 102mo
Change the automatic transmission fluid & filter. 120,000mi /200 000kmi or 120mo
Replace Accessory Drive Belt(s). 120,000mi /200 000kmi or 120mo
Old 08-24-2012, 08:43 AM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
**************************CAPACITIES************** *********
Conversion Calculator
DESCRIPTION SPECIFICATION
FUEL TANK
1500 Short Box 98L (26 US Gallons)*
2500/3500 Short Box 128L (34 US Gallons)*
All Long Box 132L (35 US Gallons)*
Cab/Chassis Models (Standard/Rear- Mount) 197L (52 US Gallons)*
Cab/Chassis Models (Optional/Mid-mount) 83L (22 US Gallons)*
ENGINE OIL WITH FILTER
3.7L 4.7L (5.0 Quarts)
4.7L 5.6L (6.0 Quarts)
5.7L 6.6L (7.0 Quarts)
5.9L/6.7L Diesel Engines 11.4L (12.0 Quarts.)
COOLING SYSTEM
3.7L 15.4L (16.2 Quarts)**
4.7L 15.4L (16.2 Quarts)**
5.7L 17.7L (18.7 Quarts)**
5.9L Diesel Engine 26.5 (28.22 Quarts)**
6.7L Diesel Engine 21.4L (22.6 Quarts)**
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
A/C REFRIGERANT SYSTEM
3.7L/4.7L/5.7L Engines 0.728 kg (1.604 Pounds)
5.9L/6.7L Diesel Engines 0.850 kg (1.873 Pounds)
AUTOMATIC TRANSMISSION
Service Fill - 42RLE 3.8L (4.0 Quarts)
Overhaul Fill - 42RLE 8.3L (8.7 Quarts)♦
Service Fill - 45RFE/545RFE 4X2 5.2L (5.5 Quarts)
4X4 6.2L (6.5 Quarts)
Overhaul - 45RFE/545RFE 14 -16L (14.8-16.9 Quarts)♦
Service Fill - 48RE 3.8L (4.0 Quarts)
Overhaul - 48RE 14 - 16L (14.8 - 16.9 Quarts) ♦
Service Fill - 68RFE 4X2 5.2L (5.5 Quarts)
Overhaul - 68RFE 15.6 - 16.6L (16.4 - 17.5 Quarts)♦
Service Fill - AS68RC 6.8L (7.2 Quarts)
Overhaul - AS68RC 13L (13.74 Quarts)♦
MANUAL TRANSMISSION
Diesel Engines - G56 5.6L (12 Pints)
5.7L Engine - G56 4.7L (10 Pints)
GETRAG 238 2.2L (4.6 Pints)
TRANSFER CASE
NV241 GENII 1.6L (3.4 Pints)
NV243 1.6L (3.4 Pints)
NV244 GENII 1.6L (3.4 Pints)
NV246 1.9L (4.0 Pints)
NV271 1.89L (4.0 Pints)
NV273 1.89L (4.0 Pints)
FRONT AXLE ± .03 L (1 oz)
C205FD 1.6L (56 Ounces) <--1500 models
9 1/4 AA 2.2L (74 Ounces)
9 1/4 AA EL 2.0L (68 Ounces)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1L (72 Ounces) ***
10 1/2 AA 2.5L (85 Ounces)
10 1/2 AA EL 2.5L (85 Ounces)
11 1/2 AA Open 4.2L (142 Ounces)
11 1/2 AA Trac-Rite 4.0L (135 Ounces)
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
Quick Reply: ---------->3rd Gen Ram SERVICE & MAINTENANCE FLUID Specs! <------------
