Last edit by: IB Advertising
Browse all: General Overview
- Dodge Ram 2nd, 3rd, 4th Gen How to Maximize MPG
Step by step instructions for the do-it-yourself repairs.
How to Improve Gas Mileage in 5.7l HEMI?
#42
If you want better MPG, drive it like and older person because nothing mechanical is going to get you better mileage
#43
You're going in the wrong direction. Those mods are used to make more power. To make more power you need more fuel. If you want to get more air in and out, your truck is going to add more fuel to that more air.
Making an engine more efficient and making more power are often the same thing- but folks don't take advantage of that.. instead they race around and complain about mileage.. a great big cam ain't gonna help things, especially if it is a bad match w/ the gears/weight/use.. but a cam (on these things) that lowers the torque curve matched to the transmission, gears, and expected use will help economy big time- but never so 'big' that is justifies the cost of doing so..
cheaply reducing parasitic loss of power is the best way to improve mileage WHILE improving performance, too.. rocker rollers instead of pivot rockers, efan, anything that allows the engine to produce power quicker- so you're no lugging about trying to build RPM's and get to the range required to do whatever job you're performing.. freer breathing intake and exhaust do that too- but not necessarily colder air.. colder air is MORE air, and needs more fuel, and even then you are limited by the mechanical relationship of overall gearing ratio's which is married to engine RPM's..
it's all about engine load in the range you most often find yourself, and eliminating parasitic loss the best you can.. little things like an efan, like rocker rollers, like better engine and drive line lubricants help- but, anything beyond that is going to take a long time to recover the cost from a few drops of gasoline..
#44
#46
Hear, hear! The tiny fuel cost/mile gained by gears, programmers, etc., etc. will almost never break even, much less provide any real saving.
#47
I went to 4.56:1 gears, and saw a dramatic increase in mileage when towing- and towing was the purpose of having that rig.. pulling a 5500# trailer netted me around 6MPG w/ factory 3.92:1 ratio's on 34" tires.. dropping about $1k on gears, and another $3k in various parts and pieces brought that average to around 9MPG... driving anywhere from 400 to 1k miles a week over a period of three years, I'm thinking I made a smart move.. but there is more to it than just economy of fuel use-
gears make life easier on the transmission, and keeps the engine from lugging as much.. that extends the transmissions life tremendously.. I ran a 46RFE in that thing, and a rebuild costs somewhere in the neighborhood of $2k, and upwards of $3.5k..
any part that reduces parasitic loss of power increases mileage while at the same time reduces wear.. such as rocker rollers- that simple mechanical pivot being replaced with less friction (which equates to less force needed from the crank/cam relationship to actuate the valve train) lets free a few ponies, but also less wear.. anything that uses the crank that doesn't move you forward is loss of power, and causes wear that doesn't need to exist.... rocker rollers cost around $250 for the 5.9 V8.. I dunno what they run for the hemi.. within the life of an engine, say, 10 years for speaking terms, they will pay for themselves in economy, but pay even more with reduced wear on cams, bearings, lifters and push rods.. you won't see that savings unless you keep your rig a while, but I'd guess it to be the difference in rebuilding in ten years or rebuilding in twelve to fifteen... yup.. that much..
an efan is a no brainer.. I had about $150 in my rig and watched the fuel mileage drop around 2 whole points while driving in the city.. a dang efan, if you operate in the 60/40 highway to city driving range most of us do, will pay for itself in the first year..
at the point exhaust needs to be replaced, it's a no brainer to open it up to breathe better.. more efficient air-in-air-out allows the engine to operate cleaner and with less effort.. yeah, there is potentially more air and therefor fuel being introduced if you have a heavy foot- but if you don't, you can reach the RPM level needed to perform the function quicker and maintain it easier (keep that vacuum high!) to conserve fuel- it would likely take a couple years to pay for itself..
big cams built for high RPM usage, stupid high stall t/c's, boosting w/ bottles or high volume s/c's instead of smallish turbos or low volume s/c's, designer exhausts, fancy intakes/throttle bodies- these are a waste when it comes to chasing economy, OR longevity.. they sure are fun, though, huh?
fwiw, though, I got tired of twirling wrenches on that silly gasser to coax it into doing what I wanted.. I crunched the numbers and sold the hades out of it and went diesel.. I tug around 12K# now and stay in double digit fuel mileage (diesel costs the same as high octane I ran in the gasser) and I have a TON more power and torque..
quite frankly, I've determined a 1/2 ton truck is a waste of function.. if you need a truck, get one- don't get a p/u body wrapped around a performance car's engine (which is precisely what the hemi is- the torque curve is too high to make it useful as a truck is intended)... that said, for the time I used that 1/2 ton 5.9L V8 as a truck was intended, I have ZERO doubts most the mods I did to it paid for themselves over the long haul- and at least half of that figure was in fuel savings..
#48
I'd reckon that depends on how much you use your truck, or how long you plan on keeping it?
On the dyno my 06 Hemi had made all it's torque by 3900 rpm which is a very usable number. Maybe your 360 didn't make torque that low, but the Hemi will
#49
it's my opinion, and likely not a popular one in a forum full of hemi owners, that anything with a curve north of 3kRPM's is a bad match for a p/u..
let there be NO doubt that 5.7 is more powerful than the 360 in dang near any form.. even if you build them out, the hemi has more potential... a 408 (4" stroke, .030 over) 360 is perfection for a truck engine, imHo, but one mother mopar never made.. on the track? the hemi is superior all the way around.. towing a 5k# trailer 500 miles @ a 60/40 cty to hwy ratio? Give me the 360.. no- give me the 408, actually, but I'll take the 360 over the hemi..
#50
The factory 20s are costing you a bit at the pump, 17s with the same diameter tires would gain you around 2 mpg - probably the biggest bang for the buck. E-fan is a great mod as the initial cost is low and can be made up with fuel savings within a year. Anything else except a good tune up and using synthetic fluids wherever possible will just cost too much for the gains to be made up at the pump without waiting beyond the life of the truck.
I'm pretty much in the same boat, I average about 13.5 and my daily driver's engine just decided to take a sh*t VERY prematurely! Which means that for the first time since 2005 my truck is my daily driver. But any major changes to the truck would just take WAY too long to make back at the pump.
Trading in a paid off truck in good working condition for one that might net you 2-3 more MPG just isn't going to be cost effective either. You'll have more in one month of payment than it'll save you on gas in a year...
