"Check Engine" Error Code P 0344 - DodgeForum.com
Old 05-10-2007, 09:21 PM
C5Vetteboy
C5Vetteboy is offline
Default "Check Engine" Error Code P 0344
Check engine light has been intermitently coming on esp after fill-ups and now it remains on! Found error codes to be P 0342, P 0456 and P 0344. Found bad hose coming from the Purge cannister and repaired. Pulled fuse # 13 and the light has gone off but after driving approx 5 miles the light has come back on and showing only a P 0344 code. Also notice that the Cruise control indicator will not come on when trying to turn on the Cruise thus no Cruise indicator light will come on nor is it operable! This Dodge Ram Quad-Cab w/4.7 has not had any mechanical add- ons or conversions and was purchased new! Mileage is 78,500 with reg oil changes, just had brake job to fix the never ending brake shimmy that has always been present and just had a new set of Bridgestones installed! Need to know what is causing this error code P 0344 and what repairs are needed! The code reader says Camshaft Position Sensor Circuit Intermittent. What is simple terms is the meaning and what repairs are needed? Was hoping to keep this truck for a couple of years longer but not so sure if it is fixing to need ongoing repairs.
Old 05-13-2007, 10:19 PM
hemi348
hemi348 is offline
Default RE: "Check Engine" Error Code P 0344
ohh wow I have this same problem. After fill ups the light comes and and I looked it up and it is (evap purge). The light will stay on a few days then go away.
Old 05-13-2007, 10:37 PM
helopilot
helopilot is offline
When you guys fill up do you pull the hose out after it clicks off or do you put a little more in to round it to the nearest dollar?
Old 05-15-2007, 03:21 AM
hemi348
hemi348 is offline
I have watched this and have 38k now on my 03 hemi ram. It's when i have a pump that is high flow - If I half gas it, it wont come on but those high flow gas pumps at the stations usually set it off. Either I have a bad censor or gas is getting into somekind of overflow.
Old 05-15-2007, 03:24 AM
hemi348
hemi348 is offline
and this is on any kind of fill-up. Half tank, full tank basically anything.
Old 05-19-2007, 06:58 AM
ccm182
ccm182 is offline
my check engine light came on today when i filled my truck. i am not sure what the code is yet but did you ever figure out how to fix it?
Old 05-19-2007, 08:44 PM
marv54
marv54 is offline
When my cruise light didnt come on, the truck also ran like crap could not pass anybody, also little volt light flashed. I foud out that it was the map sensor was junk cost me like 65 bucks and changed it my self. Dodge updated the map sensor so if old one dont have screws holding it in then you will need some. Hope this helps you out!!
Old 02-27-2013, 03:09 PM
walford6
walford6 is offline
New Member
I just changed the cam/crank shaft positioning sensor on my 03 dodge ram 1500 4.7L engine after engine code PO344 came up on my code reader. I reset the code, twice, and after 10 minutes of driving, each time, the engine light comes on and the engine shuts down. No acceleration until I shut off the the key while rolling and restart the engine. Any other idea what could be causing the power loss?
Old 12-11-2013, 09:10 PM
psychlor's Avatar
psychlor
psychlor is offline
Default p0344 code
I had a p0344 code pop prior to filling up. Since it is -15 degrees here in ND today, I dumped a can of Heet into the old girl 04 qdcb 4.7l and filled it up. The code stayed and it was chugging at 2500rpm so I dumped a couple more Heet in her. Still having issues. Recently changed plugs and water pump. I have had same issues in past but usually fill it up and drop a heet and it goes away.
Related Topics
Thread
Forum
Replies
Last Post
trevquinn
3rd Gen Dakota
5
08-04-2015 10:23 AM
MoparNut87
1st Gen Durango
9
07-30-2015 05:30 PM
Sembach5
Dodge Neon
0
07-28-2015 10:14 PM
keouchao
Dodge Caravan
1
07-18-2015 11:35 PM
herche54
2nd Gen Ram Tech
13
07-17-2015 05:38 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
