No brake lights on box, 3rd brake light works.
2004 Dodge Ram Hemi. O.K., I am really frustrated. The box brake lights do not work. The 3rd brake light is working. The tail light and turn signals are working. Any suggestions? I have checked the fuses, relays and wiring. Everything seems to look good. Please help...
you can get a new light switch for about ten bucks mine went bad. but get a multimeter and check the wiring resistance from the point where the wiring splits from the third brake light back. you might have corrosion in the wires even though it looks ok on the outside. im a diesel mechanic and it happens to our trucks a lot.
i had a lamp out light come on just a couple days ago and it turned out only the brake light didnt work regular lights do but when you hit the brake at night it doesnt go off but during the day you get 1 of the filiments to go off which led me to think something else was causing the problem
I tested for power at the plug under the firewall. It was inconsistent. Same as back at the tail light. I am just wondering if the brake switch would cause that? I put one new bulb in for the heck of it but still nothing. The tail assy has 3 bulbs in one housing. The bottom is reverse, so what one is supposed to be the brake? The problem is not the tow package because it exists long before where that is tapped in. Thanks for the input guys. Any more suggestions?
Did you find the issue yet?
Trending Topics
