3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Yeah sounds like the blender door to me. The tabs that control the door are cheap plastic and they begin to twist. If one breaks off the door can dangle for a while and flutter inside the blender at high fan speed. Eventually it will break completely and cover the floor heat portion. Because of where the blender door is located, it requires removal of the dash to replace. This is an estimated 9 hour job I believe. They built a faulty part but will not do a recall because of the labor involved to properly repair it. Heater treater has a replacement with a full metal bar across the blender door that completely solves the problem forever. Do a search for blender door and there are a bunch of quick fixes through the glove box. Not a complete and proper repair, but stops the noise.
