Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram Tech
Sign in using an external account
Register Forgot Password?
Limited Slip Differential Fluid?
Thread Tools Search this Thread
  #41
Old 03-26-2008, 12:57 PM
RamItOne RamItOne is offline
Default RE: Limited Slip Differential Fluid?
instead of reading their fluff find out the specs
amsoil 75-90 severe gear, rated up to 100,000 miles
btw mob1 flash point is 175 C vs 220 C quite a big diff for your diff.
[align=center]TYPICAL TECHNICAL PROPERTIES
revised as of 10/07
[/align] [align=center]AMSOIL SEVERE GEAR® Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG) [/align] Kinematic Viscosity @ 100°C, cSt (ASTM D-445) [align=center]16.7[/align] Kinematic Viscosity @ 40°C, cst (ASTM D-445) [align=center]109.1[/align] Viscosity Index (ASTM D-2270) [align=center]165[/align] Brookfield Viscosity, cP (150,000 Max) @-40°C [align=center]68,150[/align] Flash Point, °C (°F) (ASTM D-92) 150°C Min. [align=center]220 (428)[/align] Pour Point, °C (°F) (ASTM D-97) [align=center]-50 (-58)[/align] Copper Corrosion (ASTM D-130) 1b Max @ 121 °C (250°F) / 3hr [align=center]1b[/align] Falex Procedure B (ASTM D-3233) (failure load, lbf.) [align=center]2500[/align] Foam Stability (ASTM D-892) (20/50/20 maximum) [align=center]0/0/0
[/align]
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
  #42
Old 03-26-2008, 01:03 PM
NYPANAMA42 NYPANAMA42 is offline
Hey RamitOne, i'll be honest with you i saw the same chart on Mobil 1's website, and didn't post it, because to be honest with you again, i don't know what none of that $!%T stands for........I just know i like Mobil 1's synthetic oil...
__________________
2002 Dodge Ram 1500 Quad Cab 4X4 4.7LTR V-8
K&N Air filter system
Westin Nerf Bars
Line-X Bedliner
Tow Package
Flow Master Super 40 Muffler
Mobil 1 Synthetic Oil
8th Div. Alpha Dogs.
  #43
Old 03-26-2008, 01:06 PM
what mob1 motor oil do you use?
  #44
Old 03-26-2008, 01:17 PM
heres an easy to read graph on one of (well my 2) the two most important tests on oil, Flashpoint and this one, the ball wear test
-Click the image to open in full size.
  #45
Old 03-26-2008, 01:19 PM
5W-30 Extended mileage. good for 15K Miles. but there"s no way i'll keep it in there that long.....probably change it out around 9K-10K miles...
__________________
Westin Nerf Bars
Line-X Bedliner
Tow Package
  #46
Old 03-26-2008, 01:34 PM
be carefull what filter you use, a lot of filters are still designed for low mileage intervals. I use amsoil 25k mile oil and replace every 7500.
  #47
Old 03-26-2008, 01:53 PM
Funny, but i use Mobil 1 oil filters too.....i guess i should be a spokesman......
__________________
Westin Nerf Bars
Line-X Bedliner
Tow Package
  #48
Old 03-26-2008, 03:39 PM
mmstar23 mmstar23 is offline
so do i have limited slip or not?
  #49
Old 03-26-2008, 03:53 PM
you dont.
did you get my skype?
  #50
Old 03-26-2008, 05:56 PM
HammerZ71's Avatar
HammerZ71 HammerZ71 is offline
Dodge Forum Administrator
Vehicle: 2014 2500 CTD 4x4
Quote:
ORIGINAL: NYPANAMA42
The oil isn't the issue, it's the filter. I have just tried Royal Purple in the Jeep and with a good filter (I only use Mobil 1 or a Wix - but have read good things about the K&N, and I like the nut on the top, so I may try one next) and I'll extend my normal 3k change to 6k, which is the longest I'll trust ANY oil filter for...
  #51
Old 03-26-2008, 06:38 PM
Quote:
ORIGINAL: HammerZ71
The oil isn't the issue, it's the filter.* I have just tried Royal Purple in the Jeep and with a good filter (I only use Mobil 1 or a Wix - but have read good things about the K&N, and I like the nut on the top, so I may try one next) and I'll extend my normal 3k change to 6k, which is the longest I'll trust ANY oil filter for...
OK, i see your point......never really thought to much about the oil filters. I automatically figured that they could handle the miles without a problem....Presently i am using Mobil 1 oil filters, which i BELIEVE is capable of handling the oil and miles..If not, then i might try something else.
__________________
Westin Nerf Bars
Line-X Bedliner
Tow Package
  #52
Old 03-26-2008, 06:57 PM
so if i dont have LSD then what fluid do i need?
royal purple gear oil 75/90?
  #53
Old 03-26-2008, 07:44 PM
Quote:
ORIGINAL: mmstar23
No Mazola Corn oil....since you don't have LSD....then when your truck gets a little older you can switch to 75W-90 Gear Lube...
__________________
Westin Nerf Bars
Line-X Bedliner
Tow Package
  #54
Old 03-26-2008, 08:07 PM
Just joking...Not really sure. Maybe one of the others will chime in...
__________________
Westin Nerf Bars
Line-X Bedliner
Tow Package
  #55
Old 03-26-2008, 08:41 PM
HammerZ71's Avatar
75w-140 recommended for Chrysler 9.25 rear...
  #56
Old 03-26-2008, 08:46 PM
ok. ill pick up some 75/140 royal purple gear oil when i head back to work in like 10 minutes
  #57
Old 03-27-2008, 04:29 PM
schmedly schmedly is offline
I didn't read the entire thread, but there is a lot of apples to oranges compaisons here. The 2500 uses no friction modifier in the newer trucks as they use a totally different type of unit that does not use friction clutches. Friction modifier is supposed to be used on friction type units even if you use synthetic lube. The 4 oz vs the 5 oz spec on how much modifier has to do with which year and rear end manufacturer was used. The older Dodges used the Dana differentials and they called out a 5 oz. spec. I know because I had a '98 with the Dana. The newer trucks with the American Axle rear end uses 4 oz of friction modifier. Dealerships in my area get around $8 per 4 oz. bottle. The older trucks also did not spec out synthetic rear lube as they do now and the viscosity spec changed with that as well.
Tags
02, 1500, 7592, additive, change, differential, dodge, equivilent, fluid, gl5, limited, mopar, oil, oils, ram, rear, slip, synthentic, synthetic
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Internet Brands, Inc.
Contact Details & Emails
