mopar oil =who makes it? mopar oil filter who make it? Plugs can i run plaitum champions
RE: mopar oil =who makes it? mopar oil filter who make it? Plugs can i run plaitum champions
ORIGINAL: cyclone429
All 5.7 hemi's have 2 plugs per cy, 16 in total, the 5.9 has one plu per cy, for a total of 8, just be real glad you don't have to change plugs on a hemi 300/C, charger,
ORIGINAL: 05ramhemi4x4
I called Dodge they said my Truck only has 8 cyclinders and 8 sparkplugs.. what year is your truck?
Bec the flex fuel 8- cut to 4 cyclinder started in 2006...
Is your truck a flex fuel?
I just popped the hood.. doesnt look that hard..
I saw coils what by side to the sparkplug or something in that naturl..
Yur saying theres plugs under the coils plus under the wires?
Changing the back four plugs is a bit of a challenge... wobble extensions and sparkplug sockets make it fairly easy.
Do you no what oil mopar oil is for sure.. To diffrent dealers say its valvoine and the other says its mobile 1...
Probably not Mobil 1. Could be any of the name brands, and probably varies on who had the best deal at the time.
I have been running Penzoil in everything I own since 1979 and have NEVER had an oil related problem, even in my race cars. The only oil I have ever seen with sludgeing problems has been the dino Quaker State.
Heres a pic so you will believe there are two plugs per cylinder...
I called was on hold for 30mins with Valvoine tech..the guy said its same has mopar oil same asmmlty line but napa oil is diffrnet but valvoine
Why not just go get some quality Royal Purple, Amsoil, or Mobil 1 synthetic oil and put it in there? That way you know for sure what you are getting and no it's quality oil. I personally run Royal Purple in all of our cars, and the truck.
I dont know why I just read this thread. Thank god it was just over a page. Are you sure you bought the hemi??
Run your vin in carmax and see what it says. Maybe someone put up hemi badges on it.
Um a cooler engine will do nothing for hp, if anything the gas won't fire as strong as in a hotter engine.
Maybe if you put a jet 180 decal on your truck, yep that's where the hp comes from.
My dealer openly says they run Valvoine. Hemi's get 5w20 in there. You have your choice between Dino, Blend and Full Syn.
I would just run royal purple also, since I use it in my trail toys, but with the LifeTime powertrain I will let the dealer do them.im
