Sludge still a problem on new 4.7L?
My son and i went to the local dragstrip last night and there was several ram hemis there and they ran between 70-72.5 mile per hour in the 1/8 mile track, what was bad was a stock 08 chevy with their v-8 ran it at 75 miles per hour. the trucks were not qc or even ext.cabs .Mybe the rams had a taller gear??
I have a 2002 Quad Cab 4.7L and have NEVER EVER had any sludge... I'm a firm believer that bad maintenance causes sludge! Also, I have used Mobil1 Full Synthetic since day one... so I feel thats one reason for the LACK of sludge and may have helped. I put 5,000 miles between Oil changes. With over 110,000 HARD "Wide Open Throttle" miles I have not had any issues with my 4.7L... and it will WHOOP a HEMI any day! 9.49's in a 5200lb 4.7L Quad Cab is not bad.
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
on
Oh, but I get to pick the track though - and trust me, ain't gonna be anywhere close to pavement... Mud, water, stumps on it probably, but no asphalt... and winching across the finish line counts!!!
Hell you say! Very few power mods here, compared to you anyway. Mainly off-roading mods (although I do have CAI, LT Headers, SC, a few others plus a KRC Cam & SCT tune in the near future) and I weigh in at almost 7000 lbs. with the lift, winch, etc. plus a full toolbox (mostly welding & recovery stuff) and my fat a$$ in the truck. And my Hemi will still whip your truck any day of the week!!!
SPEED SAFE, AIR RAM
OK 4.7 here with 140 k on it
OK as of recently Ive notice some noise like a rocker ticking I tried all the clean outs .... not gonna work I finally dove off and pulled a vlave cover and a rocker arm off and the lash adjuster collapsed and stuck down ..... lo and behold I pulled the front cover to check for the demon sludge thing.....I had never changed my pcv valve and it still worked fine but did have some build up around it..... nothing like i seen in the pics while visiting here.... but I had noticed a slight hydraulic lifter noise or something close .... well it also had a chain tensioner going out or not working well due to some SLUDGE built up in the inlet not allowing anymore oil into the tensioner body .....but hey I have treated her fairly hard mashing the throttle when Im fumed at the wifey more than once and lets see my boy has wrecked it twice and my wife once ....Damn thing keeps on going.
but the timming chain set is killing me ..... plus 16 lash adjusters .... I shouldnt complain but Im a tight a$$
