windshield washer
Old 09-10-2008, 08:12 AM
whipper61's Avatar
whipper61
whipper61 is offline
Default windshield washer
Hello,
I have a 2005 Ram 2500 quadcad diesel. Only had it for a few months and love the truck. I noticed the other day that windshield washer is not working. Not sure if it has worked since I bought the truck, but its definitely not working now. I could not find a listing for a fuse in the box under the hood. When I push the switch the wipers work, but it does not spray any fluid. I do not hear any sounds like the pump is working. Anyone have any suggestions?
THANKS,
David
Old 09-10-2008, 09:07 AM
RubberFrog's Avatar
RubberFrog
RubberFrog is offline
First, try unplugging the washer hose right at the pump and see if you can get anything to come out of the pump. That will determine if the pump is working at all. If it works, then you get to have fun replacing the washer hose.
Second, try putting power to the pump direct.
The pump is very easy to access and you should be able to do both of these fairly quick.
Old 09-10-2008, 02:07 PM
Heminator2's Avatar
Heminator2
Heminator2 is offline
That's good advice. I could not have said it better myself.
Old 09-10-2008, 03:47 PM
BEAR's Avatar
BEAR
BEAR is offline
Thumbs up
X3 thats what I was thinkin'......
Old 12-02-2008, 01:52 PM
jamesim's Avatar
jamesim
jamesim is offline
Default ram 1500 2006 windshield washer
hello
2006 ram 4x4 1500
i am having trouble looking for the fuse for the washer.
the pump works, i tested it.
it seems its not getting power. i checked all the fuses under the hood
and they all work.
does it have a separate fuse?
thanks
james
Old 12-02-2008, 02:22 PM
RubberFrog's Avatar
RubberFrog
How do you know they all work? Just because a fuse "looks good" doesn't mean it still works. Find the right fuse number in your owners manual and then either test the fuse with a meter or just replace the fuse.
Quick Reply: windshield washer
