whos in the 100K+ club?
#51
As far as I know it's all original. I bought it with 229k on it. It is in good condition though, other than a cracked dash and a small wear mark on the driver's seat you wouldn't know it has that many miles on it. Still got the window sticker for it. And, according to the carfax, I am only the second real owner. It bounced between dealerships for a while. The only major maintenance I have records of was a complete front brake job including calipers and hoses about two years ago.
I bought it with the intention of dropping a new motor in it eventually. I would love to swap in a 6.4 with a super charger, because reasons, but even a fresh 5.7 would be great. The current one ticks a bit until it starts to warm up.
It does have the off-road package, which was a plus for me. Also the tow package.
My last truck, a 96 5.9 1500 I sold with 222k, that one had the day one transmission in it.
#53
#60
2002 - 225K Miles
Hello,
Here's my baby. 2002 3.7 2WD ST. 5 sp
225K miles. Owned since new.
2013 20's
ECU at 5K (warranty)
Power steering pump at 25K (Warranty)
1 ignition coil sometime around 100K
ECU ar 35900 miles (Warranty)
Brakes at 100k and 200K.
U-joints replaced at 102K
"New" used transmission at 160K (Throw-out bearing failed and cut a groove in input shaft. It was cheaper to put a 60K mile transmission than repair the old one.
Shocks all around at 120K
Radiator and all hoses replaced at 180K
Salvage yard ECU at 200K
New battery in 2014 (original lasted 12 years!!!)
Power steering pump around 160-170K
Front hubs at 140K and 200K
Tie rod ends replaced at 200K
Aftermarket head lights from Amazon - look good, but suck otherwise.
Original exhaust!!!
20170119_204716 by TomskiTulsa, on Flickr
2013 20's
Original exhaust!!!
