How fast can you go in 4wd
Old 12-30-2008, 08:17 PM
trx450's Avatar
trx450
trx450 is offline
Default How fast can you go in 4wd
i herd couple differnt speeds i just wanted to know how fast you can go in 4wd befor messing anything up
Old 12-30-2008, 08:20 PM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
why would you want to go fast in 4 wheel drive ???when im in 4 wheel drive im eather in some sh*t weather where i dont want to go fast or im in some mud and all the tires are spinning and to busy looking ahead so i dont hit a tree.
sos's Avatar
sos
sos is offline
I think the only thing the manual says is you can't shift into 4wd any faster than 55mph, but I don't think it says a top speed. However, since you are supposed to use 4wd only when it's slippery out to help with traction, common sense says you shouldn't be driving very fast.
Old 12-30-2008, 08:24 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
A proper question for a 4x4 owner is not "How fast can I go?" (nor should it be a question for ANY truck owner, unless your name is 94rt10ohio ).
More appropriate questions would be:
"How deep does the stream need to be before I should worry?"
or
"How many logs can I cross before I blow a CV axle?"
Old 12-30-2008, 08:26 PM
ramhunter9's Avatar
ramhunter9
Unhappy
or
4,987...getting closer bud
Old 12-30-2008, 08:33 PM
trx450's Avatar
trx450
trx450 is offline
thanks for the help guys, it was more of a question towards when you are on the highway and it is snow coverd, most people are goin 100-120 kph i just wanted to know if its safe to have it in 4wd goin that fast cus on my old truck it was only good to go 80 kph
Old 12-30-2008, 08:38 PM
Power_Stroke_This's Avatar
Power_Stroke_This
Power_Stroke_This is offline
I would contact your local dealer to confirm that speed. they should know.
Old 12-30-2008, 08:41 PM
HammerZ71's Avatar
HammerZ71
I can tell you this. KRC Performance by me has modded the hell out of some Quadra-Drive SRT Jeep Grand Cherokees. They have done a couple that push 600 HP and live at the track.
The QD system basically is always in 4WD and has automatic lockers in both differentials, resulting in immediate "hook-ups" off the line, giving a tremendous advantage.
I know the engine & tranny are modded, but I am pretty sure the transfer case is stock. So I would say if their stock Chrysler transfer cases can handle it, you shouldn't have too much to worry about...
Old 12-30-2008, 08:47 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
It's 4Lo you need to worry about going fast. You can simply look at your rpm gauge to figure that out. I think it's around 35mph for 4Lo, but I was just out cruising the last snow storm at 80mph comfortably in short bursts.... Hey, I had places to go!..lol
4Hi works like a normal differential. You don't even notice your in 4hi when your on the highway or at any speed for that matter.
Old 12-30-2008, 08:52 PM
sos's Avatar
sos
sos is offline
The truck can probably handle it, but if there's a reason to use 4wd on the highway, I personally wouldn't be driving 65-75mph (100-120km/h). I see people driving Jeeps and other SUVs going that fast all the time on the highway - but remember that most of those people are idiots and think that 4wd means they are indestructible, until they spin out into a ditch. If it's slippery out, you should be slowing down whether or not you have 4wd. The people who don't are the ones that cause all the accidents that come every storm.
Quick Reply: How fast can you go in 4wd
