Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Dodge Ram 2009-Present: How to Install Shock Absorbers
Step by step intructions for the do-it-yourself repairs.
Installing shocks????????
just did bilsteins on all 4 corners couple weekends ago on my truck. dont pay someone to do it. its too easy to do on your own. i did all 4 shocks by myself in 45 min to an hour. and that includes having a couple too many beers in the process. all you need is a crescent wrench, basic socket set, and an extension.
on another note... the Bilsteins are AWESOME! night and day difference compared to the stock shocks. really smoothed out the ride on my 2500.
I got my rear Bilsteins yesterday and there isn't any hardware at all, just shocks.
Does anyone else know if these extras are needed? Or can the old hardware be reused?
thanks,
Ben
For those that bought aftermarket shocks...specifically those that cranked the T-bars, what size and model number did you get? I'm hoping to do this in the next month so just looking for a little info. With the fronts, cranking the T-bars to level, I'm not sure what shocks to get as most are associated with 3" or 6" lift...but not level or 2".
Hey JoeHemi. I'm at that point too, have the 04 4x4 with the torsion special, and I need to replace my overextended shocks with 115K miles on them. I am torn between the stock replacement that's 2" too short or the longer which may be 2" too long. I've had a guy at a shock place that suggested stock Bilsteins and another from Truxxx that would go with the longer shock.
Nuts on the bolts
Just curious when I replaced by front shocks, the bolt just screwed into the threaded hole on the control arm. One of the bolts after installing the new shock (Bilstein be5-6140-t5) seemed to come loose after a few days. Was wondering if there was supposed to be a nut that I probably lost. I am considering using some threadlocker and/or adding sleeves to the bushings, and maybe the eye won't wiggle the bolt loose.
The shocks only came with the bushings....Maybe I should have purchased the extra bushings and sleeves? I know some guys here just used what came with the shock...if you happen to be one...are your bolts remaining tightened?
