3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi, I'm new here. The check engine light has come on in my 04 Ram PU, and like to try and get an idea of what's wrong before I take it. Can anyone tell me how to get the error codes to display. I tried on off on off on with no success. Suggestions would be appreciated!
Welcome to DF Jill, Ill move this over to the 3rd gen Ram Section for better input. Some of the guys/gals over there should give you an idea of whats wrong. Enjoy the site.
not 100% sure but i think its get in buckle your seatbelt and turn the key on off on off on and leave it on and it should do it, (dont turn the car on every time just from the first click to the second and back
It should say "DONE" if a code doesnt pull up. DO the key trick then it displays codes or DONE. Codes will have a P and then numbers like P0703 or something. If that doesnt work, autzone will scan it but can't come close to a starscan at the stealer...
Good luck...
i know in my area none of the parts stores do a code scan anymore due to a lawsuit. but, i did get a nice little code scanner that also clears codes and checks all your sensors for like $40. Its come in real handy, and works nice.
you dont have to buckle you seat belt but it usually takes me like 5 or 6 tries with the on off trick before i can get it to work
