torsion bar crank, front end alignment
Them saying your truck can only be put to factory specs is just that. has nothing to do with not being able to align your truck. if you keep the t-bars cranked, they will simply adjust the caster/camber and toe alignments to factory specs and all will be good. i don't think they can comprehend or put 2 and 2 together seems to be. Factory specs will just put your caster/camber degrees back to stock which is what you want!
This.
