Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 3rd Gen Ram Tech
Sign in using an external account
Register Forgot Password?
Driver's side seat foam problems? I have the cure!
Thread Tools Search this Thread
Old 06-04-2009, 04:11 PM
TheAverageJoe's Avatar
TheAverageJoe TheAverageJoe is offline
Garage is empty, add now
Vehicle: 2006 Dodge Ram 1500 SLT
Send a message via AIM to TheAverageJoe Send a message via Yahoo to TheAverageJoe Send a message via Skype™ to TheAverageJoe
Default Driver's side seat foam problems? I have the cure!
For any of you driving a 3rd Gen. Dodge Ram 1500, 2500, or 3500 and have had your driver's side seat foam fail you. I have the cure. If you have a Lowe's and a Hobby Lobby near you, it'll only cost you around $13.00 and a little skill rather than $152.00 for new foam from the dealer. Not to mention, that new foam is going to fail you just like the old one.
Here's what you'll find when you peal back the upholstery.
Click the image to open in full size.
While searching the web for an after market part or easy inexpensive fix, I came across this link in a Dodge Cummins Diesel forum.
http://www.cumminsforum.com/forum/6-...98-seat-2.html
The frames of theses seats have a boxed frame that joins on the top of the frame and leaves an exposed sheet metal edge. This edge in addition to the sliding motion getting in and out of the trucks is tearing our foam.
Seat frame; notice the metal edge, but also notice the wires held by springs, more of that later.
The weld at the very back had some burrs, they may have started the tearing of the foam. I took a ball peen hammer, rolled the edge of the metal down, and then filed the burrs and any protrusion I thought might tear the foam.
Before reinstalling the foam, I glued some burlap over the frame. (Sorry no pic of that.)
(Burlap is approx. $2.99 a yard at Hobby Lobby. 1 yd will do 2 seats.)
For the wires with the springs, this is where the pad needs to go, directly on these springs. The springs are what provide the cushion when hitting bumps and stuff. The foam design intends to distribute the weight with out fatiguing your butt. (I donít think they quite got that part down yet.)
I used 2 inches of foam, 1 inch of 20 lb & 1 inch of 40 lb. I also place a piece of vinyl between the foam and the springs to prevent the springs / wire from tearing the foam. 20lb goes on top, it's softer.
(Hobby Lobby carries a 14"x14"x2" piece of foam that works perfectly. No cutting necessary.)
(Also, be sure to glue a piece of burlap to the bottom of the 2" foam. If you don't it'll start snowing under your seat from deterioration. The burlap strengthens it too.)
Pic just shows where it goes, doesnít include all the layers. Iíd get busy and forget to take pics.
All the tears Iíve seen, start along the bottom or the back corner, just like mine. I also noticed mine had a big air pocket where the mold wasnít filled correctly. Thatís exactly where the tear started.
I filled all the torn gaps with glue, (Weldwood landau top adhesive.) and pressed it back together. Then I glued several layers of thin burlap to the foam.
(Lowe's carries a spray on 3M water based adhesive...works great.)
http://www.shop3m.com/62497749309.html
The center of the seat will rise with the pad added between the frame and factory foam, while the sides stay the same height, this takes the pressure off the hips & or butt.
The edges at the frame are fairly thin because the factory cushion is molded to fit around the frame. To help offset these deficiencies, I added a Ĺ inch of foam to the outer and back panels.
(The 1" green foam at Hobby Lobby works just fine. You sit a little higher than you used to, but it'll settle in time.)
Pulled all back together, the seat has a slight ďpoofyĒ look, but itís a heck of a lot more comfortable, and should last much longer too.
(Mine looks like a pillow top mattress...and I love it.)
I give all the credit to "cntryby" of the Dodge Diesel Cummins Forum.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Old 06-04-2009, 04:23 PM
HammerZ71's Avatar
HammerZ71 HammerZ71 is offline
Dodge Forum Administrator
Vehicle: 2004 QCSB 1500 Hemi 4x4
Great write up, Joe. Your post has also been copied to the FAQ section as a DIY. Thank you...
__________________
Old 06-04-2009, 07:48 PM
leebo1082's Avatar
leebo1082 leebo1082 is offline
Vehicle: 2006 Mega Cab SLT 4X4 Hemi
Thanks for the write-up. I know it's only a matter of time before I have to do exactly what you have shown. No matter how careful I am getting in and out, I know what's happening under that nice gray fabric.
__________________
2006 Hemi Mega Cab SLT 4X4 Amp Power Steps, CAI, Flowmaster, and Bully Dog Triple Dog. Saving money for lift, tires, rims, gears, etc...
Old 06-04-2009, 07:56 PM
Off_Road_Teacher Off_Road_Teacher is offline
Good write up, I am glad it got posted to the FAQ section. I was considering eating less as a solution to my seat problem but I like your solution much better .
Old 06-04-2009, 07:57 PM
all of 75's Avatar
all of 75 all of 75 is offline
2003 Dodge Ram 1500
Vehicle: 03 Ram 1500 Hemi 4x4
Thank you for the how-to. How long do the seats generally last before they wear out like that?
__________________
Silver Truck Club Member, Air Bag Suspension Club Member # 1: 3.92s, tow package, 20's, Goodyear Wrangler silent armors, Flowmaster 50 HD muffler, AEM Brute Force CAI, Rhino Spray-on liner, Go Rhino SideSteps, Leveling kit,mudflaps, air bag suspension helpers and a Dixie Horn. More Mods to Come!
Old 06-04-2009, 08:02 PM
damien1023 damien1023 is offline
im sure this may have been discussed but will warranty cover this if you are still in your 3 year/36k miles?
__________________
2007 RCSB
Alpine CDA-9885 Deck
Alpine SPS-69C2 Door Speakers
Two Kicker Comp 10's
Rockford 301s Amp
LED Plate Lights
Silver Star Headlights
Old 06-04-2009, 08:25 PM
Mystro Mystro is offline
Very Good write up. This is the kinda stuff I need to know.
__________________
2006 Ram 2500 HD Hemi "Thunder Road" quad cab. Polished forged wheels, Power rear window, etc.... Cherrybomb dual exhaust, Big Tex Grille saver
Old 06-04-2009, 08:39 PM
dirtydog's Avatar
dirtydog dirtydog is offline
Moderate User
2008 Dodge Ram 1500
Vehicle: 2008 Ram QC 4x4 BigHorn
Send a message via Yahoo to dirtydog
Nice! Had to do this with my mustang seats. The sides were wiped.
__________________
4-OEM TPM Sensors FOR SALE
Old 06-04-2009, 09:12 PM
BadHab1t's Avatar
BadHab1t BadHab1t is offline
2004 Dodge Ram 1500
Vehicle: 04 4.7L QCSB
Send a message via Yahoo to BadHab1t
nice write up lots of info great idea will need this soon i fear as i think the prev owner was a lil hefty so maybe sooner than later thanx....
__________________
2004 Dodge Ram 1500 Dropped and Modded (Mine)
2012 Dodge Journey SXT (Hers)
Old 06-04-2009, 09:24 PM
Ridinhigh Ridinhigh is offline
2004 Dodge Ram 1500
Vehicle: 04 Ram 1500 QC 4x4 SLT with the HEMI!!!
good write up i noticed my foam adge was looking a little low or flat and could always go with a more comfortable seat and how long did this take you to complete just for a time window
__________________
Tags
barracuda, cherokee, covers, diy, dodge, driver, fix, foam, grand, inches, jeep, mustang, raise, ram, seat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join DodgeForum
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Contact Details & Emails
Search Engine Friendly URLs by vBSEO 3.5.2
