Blown Head gasket help
#21
Also, why tear the entire engine down inside the truck? Why not pull it out if you went on the underside as well??? Heads, the motor can stay in, but if you are touching both top and bottom, your better off pulling the motor to get the job done faster. No need to touch something that isn't broke anyways. I mean if your at that point, your better off just thinking a whole new engine because of the coolant/cylinder issue that the high mileage 4.7L's have.
If it aint broke. Don't fix it. Especially the oil pump when your working on the heads...WTF???
#22
The Guy might be better off sending the money necessary to the guy in Shreveport (?) getting the heads shipped to him, then getting them to a shop and having them checked out ahead of time, rebuilt if they're flat, buy an engine gasket set, and a new set of head bolts BEFORE he taps the antifreeze drain. Then he'll start out knowing the heads are good that he's putting on, and if the others are ok---CL.
How many of you out there would really want to tackle a head job of this sort, SOHC, for $100 ? The person that offered him to do it for that much I would be very suspicious of.
Best of Luck!!!!
Best of Luck!!!!
#23
I don't have that much money to blow right now. I wish I did, but =\ I just started my job and I didn't have one when I was away at school
#24
Best of Luck!!!!
Best of Luck!!!!
Also, I'm assuming the heads the guy is giving me are good or he wouldn't offer them to me like that so he can laugh at me when I put them in and it messes up again lol.
#26
i just posted the price of the motor to show how much it cost ,if it were i and i had it id give it to u .
only thing i have is a degree and exper.
I never ran into one off these engines but im working on t DAMN MIT3.0
and about ready to throw it threw the door . DOHC MOTOR 92
PICTURES AND NOTES ,and organize navy style bro
#27
Suspected Blown Head Gasket
I have a 2004 Ram 1500 4x4 / 318. We bought the truck new, and absolutely LOVE it. I am a real stickler for maintenance on all of our vehicles (3 Fords and the Dodge), so I am just a little "upset" that my Dodge is displaying all the signs of a blown or leaking head gasket. Error code is reporting "misfire on #1". It's pouring white smoke with a sweet smell (antifreeze, I know). Can anyone tell me WHY, with 81K highway miles, a well maintained engine is giving up on me? I don't have the $$ to have a shop replace it, and don't have the time, energy or tools to do it myself. Anyone have any experience with a product called "Steel Seal"?
Thanks!
Thanks!
#29
The 4.7 has a 10 bolt head pattern (along with 4 smaller bolts around the timing channel, this does not provide enough clamping force to sufficiently seal the head's for extended periods of time.This combined with "soft" or stretch bolts reduces the clamping force on the heads over time. This is a design defect and maked the heads very suceptible to leakage and wharpage.
The best way to remidy this problem is to use "copper coat" (a permatex product) on the head gaskets and head studs. this combination will permanently fix the poor clamping force provided by stretch bolts used at the factory.
Just remember that studs will need to be re torqued after a few heat cycles! This can be done by simply removing the valve covers, all studs will be accessable and is not a major project.
Air Ram offers ARP head studs for 4.7l's, copper coat can be purchased at any auto parts store.
http://www.airram.com/product.php?ca...productid=1274
I have 2 4.7l's sitting in my garage as we speak with engine failures due to head gasket failure, one has a washed cylinder (oil lubrication removed by excessive anti freeze in the cylinder, causing gauling on the piston skirt) and one that "hydrauliced" (cylinder filled with coolant, bent connecting rod and broke piston)
For those of you with leaking gaskets, keep an eye on your coolant levels! Overheating can cause major damage to 4.7's
#30
I left the engine in there because I didnt tear apart the whole bottom end just dropped the oil pan to get all the built up classic 4.7L sludge outta there and clean things up...
