Largest Tires I can fit
Old 10-22-2009, 01:30 AM
hemiguy0302's Avatar
hemiguy0302
hemiguy0302 is offline
would not do it unless you could by a pair for spares. 16.5 would be pretty hard to find in the event you get a flat far from home.
Old 10-22-2009, 06:49 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Damn! 15s? Cars use bigger tires than that!
When i had mine with no lift, I was running 305s with no rubbing.
Old 10-22-2009, 10:09 AM
Veibz's Avatar
Veibz
Veibz is offline
Hmmm I have 305 50R 20's on my ram.... I would think 305 would fit on the 15 as well, but i am by no means an expert, I just tell them to go wider if they can. After 3 sets of tires I am up to the 305...
Old 10-22-2009, 10:18 AM
pousaan's Avatar
pousaan
pousaan is offline
I have a 2007 Ram 2500 HD and I tried the 35x12.5x17 (equiv 315/70/17) on mine with eagle series 197 17x9 offset rims and it was a no go!!! They would rub while turning so bad, that i would have ripped my fender off. Luckily I already had a 2.5" leveling kit. Even with the leveling kit installed I had to trim a little of the fender lining. There are pics of my truck in the "post pics of your 3rd Gen" section. Hope this helps.
Old 10-22-2009, 10:42 AM
ramhunter9's Avatar
ramhunter9
ramhunter9 is offline
post your pics hear so we can see
Old 10-22-2009, 11:03 AM
pousaan's Avatar
pousaan
pousaan is offline
They are in my album! You can see it by clicking on my name, or you can go to the last page of "post you pics of 3rd gen" section.
Quick Reply: Largest Tires I can fit
