06 Ram Power windows NOT Working! - DodgeForum.com
Old 07-28-2009, 05:01 PM
george2k5
george2k5 is offline
Exclamation 06 Ram Power windows NOT Working!
I own a 2006 Dodge Ram 1500 Quad Cab and all four ofmy power windows went out. I tried checking the fuses under the hood and nothing. I couldnt find a fuse box inside the truck. Any suggestions?
Old 07-28-2009, 05:23 PM
froto'sride's Avatar
froto'sride
froto'sride is offline
I would assume that you checked the relay as well when you checked the fuse. also you may want to check the wiring harness in the driver side door. it is relatively easy to remove the door panel or just remove the plate with the controls on it. the fact that it is all four of them says that it is something to do with power supplies. hope this helps.
Old 07-28-2009, 05:25 PM
hifiwest's Avatar
hifiwest
hifiwest is offline
Yeah 90% sure its going to be the wiring harness in your door. The panel with all the switches tends to come loose on 03-06ish Rams. Jigger the wiring harness until the windows work again. Then glue or screw the panel down or the wires will come loose again in very short order.
Old 01-01-2010, 08:10 PM
bryan4321
bryan4321 is offline
there is a relay for the power windows under the driver side dash that supplies the power to the main switch that all the other windows work off. you can check the relay by removing the cover and pinching the contacts together. This relay also has a 25A fuse built into it. This is most likely your problem.
I had the same problem with my 2004 dodge ram 1500 quad cab
Old 01-02-2010, 01:11 AM
mike_r
mike_r is offline
Are the windows frozen?
Old 01-02-2010, 01:41 AM
jstmahoney's Avatar
jstmahoney
jstmahoney is offline
I had this issue on my 03. It was the window lock on the driver control. I had to replace the whole driver side unit for about $100 and that did the trick.
Old 05-14-2016, 07:59 PM
Rocknrolljunke72
Rocknrolljunke72 is offline
Default Relay location for power windows
Hey , I'm having the same issue with my 06 Ram 3500 . I've looked under driver side dash and there is s million different wires and stuff . Not sure which would b the relay for the power windows . Could u possibly elaborate a lil more as to the exact location of the relay ?????
Thanks !
Old 05-14-2016, 09:26 PM
Friar Tuck
Friar Tuck is offline
40 Amp fuse F9 in IPM on '04. not sure about '06.
Old 05-14-2016, 09:29 PM
Friar Tuck
Delete
Old 05-15-2016, 01:49 AM
Friar Tuck
Lightbulb window power
If there's no power at the "relay", check 40 AMP FUSE F9 in the IPM.
This is a 25 amp circuit breaker, not a relay. It will automatically reset itself.
Related Topics
Thread
Forum
Replies
Last Post
LONEWOLF2007
2nd Gen Durango
5
12-06-2016 05:04 PM
kassie78
Dodge Caravan
0
07-06-2015 11:23 PM
janicedauw
Dodge Caravan
1
07-04-2015 08:12 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
