3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
load based=load on the engine. like when you give it more throttle to go fast, tow, accelerate, go up a hill. with more load/throttle comes more exhaust pressure, which may leak out of a small opening in an exhaust manifold/header and cause a ticking sound.
I had the exact same problem and was also thinking it was the valves, until I crawled underneath and found the lower rear stud had broken off. All I had to do was replace the stud and not the manifold as it was finger loose. Fixed the ticking noise and now she sounds great.
hmm I have this and I just started getting a vibration around 4k and it is load based. if it wasnt dark out and pouring Id go crawl under it now and take a gander.
i cant believ it cost you that much to fix because I had the same problem I was actually missing an exhaust manifold bolt causing the tick which I thought was the HEMI tick but it cost me about 50 bucks to have it fixed and that was with a new gasget and bolt plus labor so you got ripped of my friend but glad the tick is gone
