High pitched whine at high rpms
Old 08-31-2009, 11:27 PM
flwalks's Avatar
flwalks
flwalks is offline
Something on the front belt drive would be my guess. As stated above power steering pump / alternator but it not that try the fan clutch. When they go bad they scream.
Good luck, strange noises are hard to pin down
Old 09-01-2009, 12:37 AM
hemipower05's Avatar
hemipower05
hemipower05 is offline
do u have a throttle body spacer? or do u have a little leak on your cai?
Old 09-01-2009, 12:26 PM
02Regcab's Avatar
02Regcab
02Regcab is offline
Possible your low on oil and its your valvetrain screaming at those rpms ?
I have an 02 4.7l and I think I know the sound your trying to describe..
What tune are you runnin on your SC3865 and are you running the correct octane for that tune ?
Old 09-01-2009, 01:25 PM
sofakingsuite18's Avatar
sofakingsuite18
sofakingsuite18 is offline
Could the power steering pump really make that kind of a noise? Or just the bearings in the pulley?
Old 09-01-2009, 01:53 PM
KARAM0182's Avatar
KARAM0182
KARAM0182 is offline
I have a 2008 1500 QC 4.7 with the same kinda sound perhaps and at same high RPM...my truck is stock except for a cherry bomb catback. Only 9800 miles on the truck since I bought it new last August...I was thinking mine was an exhaust leak...? Bout ready to take it to the shop that put on the system to check it.
Kevin
Old 09-01-2009, 03:05 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Dodge Forum Moderator
Are u sure it's not whine coming from your speakers? i.e.bad ground?
Old 09-01-2009, 03:15 PM
xfeejayx's Avatar
xfeejayx
xfeejayx is offline
3rd gen Ram, Newbies
if it sounds like a siren, its the power steering pump. and yes a power steering pump can do that. and yes it can happen only at high rpms.
Old 09-01-2009, 09:01 PM
donjohnk's Avatar
donjohnk
donjohnk is offline
Check your pulleys!!!!!! Mine did it this spring.... it was the idler pulley... power steering pump is also a close bet!
Old 09-01-2009, 09:39 PM
ram man17's Avatar
ram man17
ram man17 is offline
I have my chip on 91 performance and Im running 93 octane.
Ill check them out but what am I specifically looking for? And same with steering pump? what are the signs?
No throttle body spacer and I have the stock intake...
I am positive its not the speakers. its far to loud and it comes from outside my truck, in the engine. Thank you guys for all this help too.
Old 09-02-2009, 10:20 AM
sofakingsuite18
I would also like to know how to check the pulleys to figure out which one might be bad. I've tried using a stethoscope and so far I've misdiagnosed the problem twice. Anyone know any tricks on checking the pulleys to see which one might be bad?
Quick Reply: High pitched whine at high rpms
