3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey guys just wondering if you found solutions?
my 2004 1500 slt with the 5.7hemi just hit 178XXXkm and the cruise light will only come on when i going under 10km/h but wont come on while im on the highway any suggestions?
my cruise control doesn't work when I press the button but it turns on when I'm going 10 miles per hour or lower But when I go over ten miles per hour it shuts off what can I do to fix this
start by getting the truck scanned for codes. Chances are, there is something going on with the drivers side bearing hub, sometimes the wires come loose and get cut by the edge of the rotor. There can be others stuff too, but the bearing hub is the most common. Worn out hubs can also cause this.
Yep, usually a fail sensor in the hub. Mine used to do this long ago also
Hi nirose15,
Welcome to the forum. Sorry to hear about your concern. What model, model year, and type of engine do you have?
