2003 Dodge Ram 1500 5.7L Oil Pressure problem - DodgeForum.com
Old 01-02-2010, 06:52 PM
jeepfourfun
jeepfourfun is offline
Default 2003 Dodge Ram 1500 5.7L Oil Pressure problem
Hi all, I have a question about my truck....it is an '03 Ram 1500 4X4 Hemi with 85k....and it just recently started spazzing out while I'm driving. The "check gauges" light intermittently goes on and off, and when it does, the oil pressure gauge drops to zero. Then it goes right back up. Sometimes it lasts 10 seconds, sometimes it only drops about 1/8" and then returns. So I'm thinking this is easy- sensor, right? Well, and this is the kicker, there's a knocking sound coming from underneath my oil pan now. Again, intermittently. It seems to always knock around the 800-1900 RPM range, no other times.
So autopart store dude says to replace the oil pump (after he asked me if I'd checked the oil.DUH!!!). I'm not convinced. After reading a lot of threads and posts on this site, I'm thinking it could be the fill tube, clogged screen, bearings, any number of things. My question is- how do I know what the culprit is? If it is the pump, how hard is it to replace? I'm not an "ace" under the hood, but I've pulled transmissions and replaced clutches and rear main seals, so I do consider myself capable.
Any help, ideas, suggestions, etc would be GREATLY APPRECIATTED!!!!
oh- and no, I'm not driving it 'till this is fixed. Sitting in the driveway collecting snow right now.
Old 01-02-2010, 09:26 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
First off, you need to check it with a real pressure gauge and see what is going on. A mechanical gauge will give you a better idea of what is happening. Sounds like you may have a clogged pick-up screen.
Old 01-03-2010, 12:23 AM
oneHEMI57's Avatar
oneHEMI57
oneHEMI57 is offline
I installed a new 'oil switch' awhile back after having similar symptoms on my 5.7L.
Location is just above the oil filter. Slide out a little the connector colored key before pulling on the connector.
Chrysler-dealership, list 22.35 paid 15.00 +tax. for the 5.7L 2500.
P/N 5149097aa , its called 'Switch-oil'.
The tread;
http://dodgeforum.com/forum/3rd-gen-...-diagnose.html
I dissected the switch and found rust may be the culprit.
Old 01-03-2010, 02:21 PM
jeepfourfun
Thanks guys...I will try both of those ideas soon (hopefully today). I'd be stoked if I replaced the "oil switch" and that cured it, but I have my doubts.
So I know the manual pressure gauge will tell me if I really have presssure or not, and if it says I do, then my pump and everything below can be assumed functional? If not, start ripping the pan off? And would a clogged screen make that terrifying noise from the oil pan? Thanks a ton guys!!!!!
Old 01-03-2010, 03:54 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
If it has been starved for oil, It is probably bearing noise and you mine as well pull the engine.
Old 01-05-2010, 03:42 AM
jeepfourfun
Unhappy
Ok...so I had 2 guys who know 10X about trucks what I do listen to mine and they both agreed.....I'M SCREWED. So I thought I'd take this moment to vent. I struggle to pay my bills on time every month- but I do. It's sometimes hard to put food on my family's plate every night- but by God I always find a way. I give blood every 6 weeks, pray to God every night before I go to bed, bleed Red, White and Blue, SO WHY THE HELL AM I GETTING SO SCREWED?!?!?!? I still owe $13k on my Ram, which is basically a pile sitting in the driveway right now, and a new engine is gonna run me at LEAST $4k. So forget the nice $0.00 balance I just payed off on my credit card, just go more into debt, right?!? It's the American way! Maybe some nobody will come bail me out one day......oh wait- that only happens on Wall St. I knew this was coming, just trying to delay the inevitable. No idea where I go from here. Do I trade in and take a HUGE loss? Buy a crate engine? Rebuilt? Dealership? Private repair shop? I can only see 2 positives POSSIBLY stemming from this......1) I trade in and get a Cummins Diesel out of this (at a significant loss) or 2). I replace the Hemi I have now with a rebuilt or crate and repair this one and drop it in that 'ole 83 CJ7 sitting in the garage (again, at a significant loss). A Jeep with a Hemi would be sweet.......sorry for the ranting and rambling, I just feel really really ticked off because I feel like this should never happen to someone like me. I know how to work on cars.......I know what's smart and what's dumb......I know how hard it is to feed the mouths of a wife and 2 year old and 1 year old little girls....anyways....any new suggestions feel free to chime in. Thanks guys. CHEERS?
Old 01-05-2010, 04:06 AM
DodgeThunder's Avatar
DodgeThunder
DodgeThunder is offline
What exactly did your buddies that know 10x more say? Its screwed? Cause these motors tick regardless, mines only got 20,000 kms on it and it ticks... If i were you Id hook up a manual pressure gauge and get down to the bottom of it before you go jumping to conclusions.. It must just be that month cause Ive read just tonight 3 guys talkin about there oil gauges acting up.. No offence but after reading this you sound like the guy that has a car that turns over and wont start and says trash it before diagnosing it.. Its not the end of the world man, i know life sucks sometimes but you just gotta roll with the punches.. Diagnose it PROPERLY and fix whatevers wrong.. even if its a pull the motor to replace the pump job, it can be done, I wouldnt go throwing the truck at a dealership and taking the loss on it!
Old 01-05-2010, 09:22 PM
jeepfourfun
So I listened to your advice and went to dive into the oil pan this morning, and when I drained the oil, I got about 2 qts out. That's all. Slimy, not sludgy, but black and less than half of what should have been there. I can't explain it- I checked it last week and it was fine. Anways- on a shot in the dark I threw 5 new qts in there and let it sit, then fired it up and the noise was gone. My new question is- am I really that lucky? Or did I do internal damage that's just gonna sit like a time bomb? What should I do next? Thanks guys!
Old 01-05-2010, 09:31 PM
snidehockey's Avatar
snidehockey
snidehockey is offline
I had the same thing happen w/ my 00 mustang. Pulled the pil plug and about 1 qt came out...I had just checked it recently, and it wasn't burning oil as far as I knew. I however wasn't as lucky as you. One pulled engine later, I found a spun rod bearing right up at the front of the crank shaft.
Replaced the engine w/ a 2ok mile engine from a yard for 800 and got a 30k mile mach transmission for 300 and a few weeks later it was finally all set.
Old 01-06-2010, 08:42 AM
Lifted4x4Astro
Lifted4x4Astro is offline
First things first...use the dipstick! Your 5.7L Hemi engine takes 7 quarts so you are still 2 quarts low. Add 2 more and keep an eye on it. If it goes to knocking then you gotta look at swapping a used engine in. You can find them for a little over $1k...http://cgi.ebay.com/ebaymotors/2004-...item19b8fdec72
Always remember that whatever happens, you still have a wife and 2 awesome kids there by your side. In 10 years you'll look back on this and laugh as you are driving something different.
Related Topics
Thread
Forum
Replies
Last Post
dodge.girl18
3
07-22-2015 05:57 AM
Az Rob
3rd Gen Ram Tech
2
07-02-2015 02:19 PM
JLC80
3rd Gen Ram Tech
3
07-02-2015 11:39 AM
Baxter263
2nd Gen Dakota
1
06-25-2015 01:40 PM
CWM1012
Dodge Ram
2
10-10-2003 01:16 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
