The Best Transmission Fluid Recommended
ok so if i were to replace ALL the fluid in my trans, lines, torque converter, transfer case, and differentials how many quarts would that be and how would i go about doing all that? i already have RP in my engine. do i need a pump for the diffs, transfer case, and torque converter? ive been wanting to do this since last summer but just never planned it or got around to it. what type of fluids do you use for the diffs, transfer case, and torque conv?
I have heard from a local dealer here in the UK, that switching over from the OEM fluid to RP in his tranny saw a 3mpg gain???
I wonder if Weedahoe could chime in here?
Did you see any MPG gains when you changed out your tranny fluid to RP Weed?
I'd consider a change even here in the UK with the rip off we get charged for RP if the MPG goes up
Al.
Al.
Al.
Al.
Al.
Al.
Just for the record- All ATF+4 is synthetic. It's part of the specification. The stock fluid is actually rebadged Valvoline ATF+4
Here is an interesting link that shows RP is actually not approved for our trans- http://www.centerforqa.com/licensedatf4brands.html
Here is another link that shows that the ATF+4 spec is indeed synthetic- http://www.centerforqa.com/
