Help! locked out!! :(
If your were that desperate you should have even smashed a door handle off instead of the back window. Hope its not too expensive man. Also does your truck have an after market security system. My truck did this after I installed my system but I just pulled the module out re set it to default settings then re tuned it and yeah it works good.
This is why I like my old fords with the vent windows, usually the lock on the arms broke and 1 min with a hanger and your in, but once I was drunk and didnt have a hanger.. so I smashed it, 10$ at a wreckers.. You deff should have smashed a diff window though man.. Like someone else said, Im pretty sure the widows are 1 piece, try and find the piece you broke at a wreckers and see if you can get it in but im very doubtfull.. good luck, now go get a key cut and zap strap it under your truck somewhere!!
There are several methods to getting into a locked truck. I'm not sure on the schematics of the locks on the 3rd gens, but I would assume that you can take either a steel welding rod (TIG not ARC) and bend it into a check mark, go down the driver's or passenger's side window (Lower weather striping) and attempt to go under the window and push the actual lock up. If you have tint on your windows, this might not be a good option.
Another option that I use is to take either a coat hanger or a welding rod and go into the door jam. You can get it through if you take a wedge or sometimes a claw hammer and pry the top open. A good idea is to take a small thin cloth and put that on the end of the prod too so that you don't damage the paint on the inside of the door.
If you're stuck out in the field and still have that long mast antenna, you can use that as the prod too.
By far the best option is to have two spare keys. One for your wallet and one to stick in a key hider on your truck somewhere.
Ask Pyro, I'm bad about locking myself out of my truck and finally got around to having some spares made.
Oh, FYI, IF you get to the point where you decide to bust a glass, bust the windshield. Compared to the side and rear windows, it is by far the cheapest to replace.
