Keep replacing TPS! HELP!!!!
Tps help
yeah the reason I said don't tell me it's on the throttle body, was because I didn't now where that was either lol... every thread I read it said to remove it from the throttle body??? not take off the air cleaner and look to the right side you will see a 3 wire plug that is connected to the TPS, the TPS screws into the throttle body with torx screws...now that would of helped me and so did you ! thanks, changed it out and it works great again!
Well im not throwing TPS codes anymore but im still having problems. Heres my new thread... https://dodgeforum.com/forum/3rd-gen...ing-right.html Please take a look and try and help me out if possible. When i turned the TPS with a scredriver I did it very slowly and gently and I kept in mind the limited travel and the sensitivity of the part. Thanks.
