Right Power window only works from driver's side
Old 02-18-2010, 09:03 PM
DodgeGuy50's Avatar
DodgeGuy50
DodgeGuy50 is offline
Default Right Power window only works from driver's side
My '04 Ram right window only works from the driver's side. I have checked the fuses, checked for electricity on the right side and there was none. Any suggestions?
Old 02-18-2010, 09:08 PM
Marx's Avatar
Marx
Marx is offline
4 door? 2 door? need more truck info
do you have a window lock button?
Old 02-18-2010, 09:13 PM
DodgeGuy50's Avatar
DodgeGuy50
2 door. No lock button, of course.
Old 02-18-2010, 09:23 PM
tony713's Avatar
tony713
tony713 is offline
i have the same truck, slt. and i have the same problem. only happens every now and then. i noticed when the little light in the switch is on the switch works. i also replaced the switch and that wasnt the problem.
Old 02-19-2010, 12:43 AM
Marx's Avatar
Marx
Marx is offline
just sounds like a lose wire
Old 02-19-2010, 12:46 AM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
Thatonekidw/theHEMI is offline
any spliced wires anywhere?
Old 02-19-2010, 03:04 AM
Kamel87's Avatar
Kamel87
Kamel87 is offline
i have this same problem check everything samething when the light is off they dont work for the rear also but if the passenger hit the button it stops so there is electricity going to the switch it just doesnt work mines an 03 slt
Old 02-19-2010, 06:15 PM
tony713's Avatar
tony713
tony713 is offline
yea when i the driver hit the switch to make it go down and the pass hits it the window stops.
Old 02-20-2010, 12:07 AM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
i get the same intermittent problem. its seldom, but happens occasionally. i've searched a lot and havent found a fix. 03 slt here as well
Old 02-20-2010, 04:13 AM
abarmby's Avatar
abarmby
abarmby is offline
I think I read somewhere that the wires in the rubber boot betwen the door jam, get pinched/cut and cause what you guys are describing.
Al.
Quick Reply: Right Power window only works from driver's side
