06 Ram shakes bad when brakes applied!
Old 06-08-2010, 11:00 AM
outadaredj's Avatar
outadaredj
outadaredj is offline
Default 06 Ram shakes bad when brakes applied!
06 Dodge Ram 1/2 ton shakes bad when I apply brakes. AND only does so above 45 MPH. If under 45 MPH, no shakey, shakey. Anybody have any ideas? Thanks all
Old 06-08-2010, 11:03 AM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
Warped rotors is what I would be thinking.
Old 06-08-2010, 11:04 AM
sabedra211's Avatar
sabedra211
sabedra211 is offline
Your brake disc rotors are probably warped. You should get the. Resurfaced or replace them. My truck used to do it really bad but then I finally changed them last year it was fine. Now I'm starting to feel a little Shake again when breaking in higher speeds! They say it causes that when you go thru rain puddles alot? cuz the rotors are hot then they touch cold water? But idk.
Old 06-08-2010, 11:15 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
x3 on the warped rotors..........
Old 06-08-2010, 11:51 AM
ram_bo06's Avatar
ram_bo06
ram_bo06 is offline
Do you still have the stock tires? Could be that. About 6 months ago I had my stock goodyears rotated due to a similiar shake I was experiencing. My mechanic told me one of my tires was worn unevenly and that was the cause. He rotated it from the front to the back it made the shake milder. Bout a week ago I replaced my stock goodyears with cooper zeons and now she rides like a dream, smooth sailing!! I thought it was my rotors until my mechanic told me they were fine. Just my experience though...if that helps.
Old 06-08-2010, 12:12 PM
outadaredj's Avatar
outadaredj
Hey thanks guys, I'll give my rotors a look. Do I need to replace all 4 (back wheels are rotors, not drums)? I'm thinking it's one of the front one's cause that where the shaking seems to be happening, but idk, maybe just replace 'em all.
No, wheels not stock. Those were stolen about a week off the lot. Strange thing to wake up, and go out to your truck to find it sitting on blocks...
Old 06-08-2010, 12:17 PM
casper3380's Avatar
casper3380
casper3380 is offline
if your rear pads are good, you dont have to replace them, they only do 25% of the braking anyway. As for your issue, ive had a similar problem. i replaced the rotors, drivers side was warped. It is still doing it so its at the dealer today with them trying to find out why. i hope you only need the rotors replaced.
Old 06-08-2010, 05:30 PM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Power Slot Rotors! or at least new replacement (Duralast has actually been good for me in the past). I have a set of used Power Slots sitting in my shop...
Quick Reply: 06 Ram shakes bad when brakes applied!
