Painting the under carriage...?
how does the eastwoods rubberized stuff hold up to salt? up here in canada they're big on putting salt down in the summer..and then the salty air on the coasts are nasty too. thats why im fond of por15...and i dont find it takes a lot of prep work when its gonna put years on your trucks frame lol.
The frame itself is sprayed with the shootable liquid, but the airbag bracket is sprayed with the aerosol stuff. Blends in real well although the aerosol stuff seemed to be a little softer prob because it sprays a little heavier than out of an undercoating gun. I used only 1 aerosol can to get the areas the sprayer wouldn't reach,m plus the cans are good for touch ups since it blends in so well and is tuff stuff itslef. MUCH better than the 3M stuff sold at the local aut parts store. I've used both and there is no comparison.
Cleans up pretty well. Yes a little bit does stick to areas underneath where you can directly shoot it with the wand, but for the most part, it's clean anough to make me happy, but I'm not an offroad junkie so if you are, you may want to use something else such as a paint like RF showed.
I didn't want a paint because it's prone to chips and peeling because it's very thin. I actually wish I sprayed that stuff RF used first and then did the rubberized undercoating over the top of it.
I'm pretty sure that the stuff is paintable though which would eliminate the possibility of any stick mud in places like fenderwells...etc
