why does my truck smoke? - DodgeForum.com
Old 06-28-2010, 10:46 AM
maverick_124
maverick_124 is offline
Default why does my truck smoke?
so my 03 ram 1500 has been smoking for almost a year..not while driving, only at idle. and when i take of form a light there is sometimes a poof of blue smoke. is it an easy fix?? or is the motor getting ready to die?? if its an easy fix could i just take the heads off and fix it??i was told a while ago its the valve guides going bad but i dunno if it is or not..and i dunno what the compression is and im not gonna do it cause the engine bay on dodge's are retardedly crammed..
EDIT: also when i walk around the truck while its running, or just after i turn it off it smells kind of like a deep fryer or something..it dont smell like a normal truck tho..
Old 06-28-2010, 11:12 AM
Huntjunkie41's Avatar
Huntjunkie41
Huntjunkie41 is offline
Is the truck burning/consuming any oil or coolant? It is very possible it is the valve guides, but could also be the piston rings. More than likely the valve guides. It is something you would have to have done at a shop. They would have to pull the heads.
Old 06-28-2010, 11:17 AM
maverick_124
well i know the heads would have to be pulled..and it goes through oil. i cant give any idea at how much per 1,000 miles, but i know i have to put a qt in every month or 2 if im driving alot..
Old 06-28-2010, 11:54 AM
Huntjunkie41
I don`t think your engine is going to die anytime soon, but I would at least take it in for an estimate. You could try using some oil additives in the short term (though most do not recommend) to see if it helps.
Old 06-28-2010, 12:47 PM
maverick_124
well i put lucas in it and it helped ALOT
Old 06-29-2010, 03:12 PM
maverick_124
ok, would it be the guides, or the seals?? and according to this thing I found online i dont NEED to remove the heads from the truck, i just need to put 60-90 PSI of air in the cylinders to keep the valves from dropping into the cylinders..
Old 06-29-2010, 03:59 PM
Huntjunkie41
I believe the most common issue with the dodge valve train is the guides. Worn guides will consume oil. You may be able to inspect each spark plug to give you an idea of which cylinders are the worst. Replacing them in place may not get you to the root cause of the failure though. If there is allot of carbon build up on the valve stem it can damage the new guide shortly after installing it. Just something to be aware of.
Old 06-29-2010, 04:33 PM
maverick_124
well all the plugs were clean when i changed them, only the driver side front one was corroded O_o but all the rest were clean a nice tan color
Old 06-29-2010, 05:10 PM
Huntjunkie41
You should if possible get a compression check done. If your spark plugs looked clean it is either exhaust valve guides or piston rings. What engine do you have by the way?
Old 06-29-2010, 05:45 PM
maverick_124
the 4.7L that according to the Internet is very fail
Related Topics
Thread
Forum
Replies
Last Post
dael
3rd Gen Ram Tech
6
06-18-2016 11:49 PM
Khris1994
2nd Gen Ram Tech
121
10-24-2015 03:47 PM
pamela24
Dodge Caravan
6
10-21-2015 06:33 AM
NemesisPrime
18
10-17-2015 02:43 PM
kenm78
4th Gen Ram Tech
1
07-05-2015 03:05 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
