2004 3.7 Dakota, No bus no crank
Old 11-06-2019, 01:00 PM
gvent's Avatar
gvent
gvent is offline
Default 2004 3.7 Dakota, No bus no crank
The truck randomly shut off as I was driving.
- No gauges work
- No bus on odometer
- Does not crank
- I've checked all fuses and relays, starter cranks if relay is jumped, fuel pump works if relay is jumped, jumping the ASD does nothing.
replaced camshaft postion sensor.
- all grounds on PCM pins get 12v
- unplugged Crank, Cam, MAP, TPS, Oil presure sensors, made no difference.
Cam plug outer pins get 5v, 4.90-5v, middle ground pin gets 12v
I get the same voltages for Crank, TPS sensors.
I could get the MAP sensor off, it looks melted, so i cut the wires, still no bus no crank. MAP wires get 5v, 12v ground, 4.90-5v signal.
Old 11-06-2019, 01:55 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
12 volts on that ground pin ain't right. Need to find out why.
Old 11-08-2019, 11:47 PM
gvent's Avatar
gvent
gvent is offline
Problem solved.
PIN 11 FUSED IGNITION SWITCH OUTPUT
PIN 12 FUSED IGNITION SWITCH OUTPUT (OFF-RUN-START)
on PCM C1 plug
both pins should get 12v with key on position, my pin 11 was not getting 12v, so i cut the wire and jumped 12v to it.Truck started and no bus is gone.
Old 11-09-2019, 07:15 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
Hahaha, or hack the harness and tie it directly to the battery and let the next owner wonder why
Quick Reply: 2004 3.7 Dakota, No bus no crank
