problem after problem. now battery dead, doors wont unlock. help!
we're talking about whether the locks only work electrically, not mechanically. so that when the battery is dead there is no power to the only way they work? so in other words there not broken their just not designed to work mechanically... hard to explain lol
i think the first then would be charging your battery, getting power and then just hit the switch or the key fob to see if your locks are working- dont pull the panels with a dead battery its just gonna get you no wheres fast! :P and also...have you checked the battery in your key fob, ive had a customer do this and all it was, was a dead remote battery
If the key goes in but doesnt turn then the lock might be seized due to lack of use. Happened to my Integra when I put an aftermarket alarm/starter unit and didnt use the key to lock/unlock the doors for over a year. If the key goes in and doesnt turn try using some silicone based lubricant... DW40 might work but it is not as effective. I used a sh*t load of lubricant and the key/lock worked perfectly fine.
You are right, the lock is electrical, my key didn't work so i removed the door panel and an actuator type thing had come off the lock cylinder, there are no rods like in the old days. I had fortunately left my passenger unlocked when i took out the battery and only locked the driver door manually before closing it. I read that this lock will get power from the fob but I didn't test it. I would like to know a solution because I am not sure if my battery will strand me somewhere before i can get a new one!
Bad battery cable now dying/dead battery smoking under hood now locked doors
First wiggle the battery cable then it starts. Then quick drainage of battery with the cold still jumped it and held charge. Then was completely dead and wouldnt start after driving all day so charge with battery charger the door locks repeats locking and unlocking but it charged until cables came off the next charge it all day start it up and it starts smoking under hood i hurry shut it off and then find all doors locked up and won't unlock? Any suggestions to what's going on and how can I get into my car
