Ham Radio Install
Ham Radio Install
Hi everyone. I just picked up a 2008 Ram Quad Cab. The first thing I need to do is to install my ham radio. I need to run power directly from the battery. What's the best way to route a line from the battery into the cab? In my Explorer, I had to drill a hole under the foot rest pad for the left foot. I was hoping Dodge had thought ahead and provided me a convenient route.
Secondarily, I would like to connect a relay so the radio comes on when the truck is on. I'll probably power the relay from power to the stereo. Is there better way of doing this?
Truck is an SXT 4.7. Not sure if that makes a difference.
Thanks
Thanks
There *might* be a plugged hole that the clutch rod would normally go thru on the firewall. Just to the drivers side of the brake booster somewhere. (probably cleverly concealed under something........) It should just have a rubber or plastic plug in it, that you can poke a hole thru, and run wires that way.
I just installed one in mine. I screwed mine down directly over the passenger cup holder and ran the wires behind the dash. As for going through the clutch cover plate, That's where I went through. I drilled a 7/8" hole, then used a plastic bushing used by electricians in knockouts. I then sealed around my wires with duct seal.
Getting a VHF antenna mount for the hood in Canada was looking very pricey, so I just bent my own out of stainless sheet, and used the fender mounting bolt to hold it in place. Seems to hold it well, and ground it nicely too.
It's been years since I worked with these radios. A few tips on your install. Some clear silicone around the wires to seal out water is a good idea. Get some mesh ground straps and add one or two from your hood to fender. This will keep the ground plane steady. Anything else I could tell you, you probably know if you have your Amateur license.
