2-wheel or 4-wheel-ABS - DodgeForum.com
Old 01-11-2011, 03:30 AM
Rik's Avatar
Rik
Rik is offline
Default 2-wheel or 4-wheel-ABS
Hi Folks!
can you say me, if my truck has a 2- or 4-wheel-ABS?
itīs a RAM2500, 4x4, HD from '03/'04
When i brakes on snow and ice, i see in the mirrow, that the rear-Wheels blocked and only the front wheels are braking with ABS...
thx,
Rik
Old 01-11-2011, 07:07 AM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
If you have two-wheel, it'll be on the rear wheels only. Four-wheel will include the front wheels. Two-wheel will allow the fronts to lock first.
Old 01-11-2011, 07:55 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
I do believe you have 4wabs. The abs controller has the 2 connector plugs and 4 lines going out. At least that's the same controller on my RT and I have 4wabs.
Old 01-11-2011, 07:58 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Taking a picture of the ABS module wont tell me anything but if you need to know for sure, get under the truck and look at the spindles and there would be a wire coming out of the wheel bearing hub. That wire is the ABS sensor in the hub assembly.
Here is a stock photo
Related Topics
Thread
Forum
Replies
Last Post
shockracer
3rd Gen Ram Tech
0
06-28-2015 08:25 AM
99dodge318
2nd Gen Ram Tech
21
11-07-2011 02:42 PM
clyde714
1st Gen Durango
32
04-24-2010 11:31 PM
clyde714
1st Gen Durango
2
01-07-2010 01:54 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
