4.7L burning oil like gas
I have a 2002 Dodge Ram 1500 4x4 4.7L with 180,000 miles that is burning a ton of oil. I am not much of a mechanic, and I need some help with where to start troubleshooting. I get the oil changed regularly (every 3,000 miles or so). Yesterday I put almost 5qts in, which means there was basically no oil. There are a few drops of oil on the driveway, but nothing that would indicate losing all of my oil in a few months time. The coolant doesn't seem to be milky. What else should I be checking?
180k is a lot on a gas engine. Are certainly need to check for external leaks and if there are none or very small ones then you would be burning oil INSIDE the engine.
If it is internal then you would be blowing smoke when you first start it up or while driving it.
If thats the case and with you at 180k, then it is time to a rebuild or re-manufactured engine
See now weedahoe - words and phrases like "180k is a lot on a gas engine" and "rebuild" those don't really need to be part of the solution.
Firefighter when I was given the truck I was warned that it burned oil, but this is crazy. The tailpipe is certainly black, but all dry. Also, I've never noticed it smoking.
Geezir it was surprisingly dry and clean. The only thing I really saw was the oil I spilled when filling it back up and some transmission fluid which is less than encouraging.
Starting to think I should go back to my vehicle description page and check the "for sale" box.
The coolant won't be milky if oil is getting in. There just will be oil floating on the coolant. If coolant is getting in the oil, the oil might be milky. If it isn't leaking, it must be burning. Five quarts in 3k miles? It must be going somewhere. I suspect you might want to look closer for smoke. A compression and a leak-down test sound in order.
Like I said, lift the hood and look top top of the engine and look at the sides of the valve covers. Its there oil present? Get under the trick and look at the front of the oil pan (front engine crank seal) and the rear of the oil pan (rear main seal). Is there oil present there?
At 180k Im sure your have external oil leaks and Im sure you have at least a rear main leak. But I still believe you have excessive internal wear in the valve guides and piston rings.
Trending Topics
OP...have you found anything yet?
