2004 RAM 1500 Wheel Noise?
Old 05-09-2011, 06:20 AM
Gorhad's Avatar
Gorhad
Gorhad is offline
Default 2004 RAM 1500 Wheel Noise?
Just brought a 04 RAM 1500 Quad cab but its got a sort of rumbling noise on the passenger side wheel. When turning right say going round a RH bend the noise goes off. I was thinking maybe a wheel bearing gone bad?
Any input would be appreciated
Thanks
Old 05-09-2011, 11:27 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
When you say "just bought", how long ago was this? You have the right idea about the wheel bearing but the only way to know for sure is to jack it up and check it out
Old 05-09-2011, 06:04 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Got it Friday just gone. I knew it had a couple of problems and thought for the price i could get it fixed.
I drives fine other than this hummmmm noise from passenger side front wheeel on a left hand turn/bend goes off a little on the straight and nothing on a rh turn/bend
Old 05-09-2011, 08:43 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
Ok jacked it up and got a little play about 1/4 inch or so diagonal across wheel nothing vertical or horizontal . Spun the wheel and I can hear a slight grinding noise.
Old 05-10-2011, 09:06 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
So if you are spinning the tire and hearing grinding it is either the brakes hanging or the wheel bearing. Should be easy to tell which it is
Old 05-10-2011, 10:50 AM
Gorhad's Avatar
Gorhad
Gorhad is offline
Thanks weedahoe, ordered the new bearing and hub with the ABS lead. Now onto my other prob the annoying squeak
Old 05-10-2011, 12:37 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Squeaks are easy most of the time. Just find the area where you think it is coming from and spray it with WD40 or something similar. Then you can start narrowing it down to a smaller area or item as the culprit
Old 05-10-2011, 01:39 PM
Gorhad's Avatar
Gorhad
Gorhad is offline
so do i start a new thread for the squeak
Old 05-10-2011, 01:43 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
LOL....I wouldnt unless you cannot track the noise down or just feel the need to create one. Im not anyone to tell you NOT to create one. Obviously you would not want it tied to this thread and issue. A new problem get a new thread.
Old 05-10-2011, 02:17 PM
truegent81's Avatar
truegent81
truegent81 is offline
I'm gonna jump in on this squeak issue too. Gorhad does your truck squeak sound come from the wheel assemblies? I have an annoying squeak coming from the rear assemblies I believe. I only hear it when coasting through a parking lot. Once I touch the gas pedal, it goes away until I'm coasting again at parking lot speed. What can you not spray with wd40 or liquid wrench on an assembly?
I thought they made a spray specifically for brakes and was safe to squirt on the rotor or pads?
Quick Reply: 2004 RAM 1500 Wheel Noise?
