Shifting out of park, Ram 2500
Old 05-10-2011, 02:12 PM
Lov24x4's Avatar
Lov24x4
Lov24x4 is offline
Default Shifting out of park, Ram 2500
Ok so i got a new (to me) 2007 Ram 2500 5.9 turbo diesel. I like it a lot and it doesn't seem to have any other problems other than the shifter. When i shift out of park, it is almost like i am not pushing the brake. It will come out of park but it is hard to pull down. I have brake lights so my next step was to removed the shifter cable from the trans and the shifter will move free up and down. I would guess that tells me the problem is in the trans. I dont know much about dodge, or diesel but i know my way around a car. Has anyone heard of or had this problem?
oh and it has 94k
Old 05-10-2011, 02:19 PM
dustyloins's Avatar
dustyloins
dustyloins is offline
Hall of Fame Member
Location: Alamosa, Colorado (200 yards from the Rio Grande)
Welcome to Dodge Forum!! Check out our Ram Section!!
Dusty
Old 05-10-2011, 08:13 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
Dodge Forum Moderator
Welcome to the site. I will move this thread to the third generation Ram section,
FF
Old 05-14-2011, 04:23 AM
Lov24x4's Avatar
Lov24x4
Lov24x4 is offline
still haven't fixed the shifter problem but i will this weekend i hope
Old 05-14-2011, 08:43 AM
Geezir's Avatar
Geezir
Geezir is offline
Can you hear the shift lock unlocking when you hit the brakes? If you listen carefully you should hear the click of the lock unlocking.
Old 05-14-2011, 03:53 PM
Lov24x4's Avatar
Lov24x4
Lov24x4 is offline
Ya that is working properly and I can here it. Seems to me that the parking pawl is hanging up in the trans. But I don't know if there is anything else it could catch on. It will come out of park, just like I am on a big hill all the time
Old 05-14-2011, 07:34 PM
mike_r's Avatar
mike_r
mike_r is offline
Is the stock torque converter? I have an uncle with a 2500 CTD with an after market, lower stall converter and it's hard to shift out of park.
Old 05-15-2011, 04:18 AM
Marx's Avatar
Marx
Marx is offline
try putting the truck (from drive) in neutral then setting the parking brake then putting it in park. this should relieve the pressure on the parking pin, witch may be the problem
i know my truck is hard to get out of park if its on a bit of a hill, if i don't use the parking brake
Old 05-15-2011, 01:34 PM
Lov24x4's Avatar
Lov24x4
Lov24x4 is offline
Thanks for the tips but still no luck. Its not the converter, it is stil hard even when its not running. And I have tryed pulling it out of park up hill, down hill, flat ground, brake on, and even in and out of park in the same spot not running several times. Its always the same.
Old 05-15-2011, 01:43 PM
Lov24x4's Avatar
Lov24x4
Lov24x4 is offline
At this point I feel like it is normal but I got into 2 other trucks just like mine to try the shifter and they are smooth
Quick Reply: Shifting out of park, Ram 2500
