MDS solenoid causing transient misfires
My '07 5.7 started misfiring on cylinder 5 a little while back and kicked two codes -- misfire on cylinder 5 and reactivation control performance (cylinder 5).
I replaced the coil on #5 and changed all of my spark plugs yet the problem continued. After speaking with a Dodge dealership they suggested I reset the PCM which corrected the problem... kinda.
The truck will run great; no hesitation, strong like bull. Then almost out of nowhere this condition starts and cylinder 5 misfires. It sometimes lasts until I reset the PCM, it sometimes clears itself up after a few seconds, and sometimes it goes away if I shut her off and re-start.
Since the truck runs perfectly when not in this condition I've refused to let the dealership charge me for a tuneup (that I've already done) and a fuel system cleaning. They charged me $250 for a PCM software upgrade which was a huge waste of money, and nobody seems to be able to tell me what "reactivation control performance" means.
My guess is an MDS solenoid that is acting up. I contacted a different dealership, and the tech I spoke with agreed that it's the likely culprit -- the problem being this $60 solenoid costs $500 to replace with no guarantee that it will fix the problem.
Any advice from you techs out there?
Thanks,
-Ryan
Thanks,
-Ryan
dodge 5.7 misfire
i have a simular issue i have #7 misfire i have tried pcm coil cps crank p sensor sea foam ohmed all wiring cant find the issue. it was better after sea foam so i replaced mds seloniod still did not fix so my next step was lifters for #7/5 cylinders in process now but there is nothing else it can be head gasket looks good valves ok springs not broke fyi i pulled head withe exhaust man intact and was able to pull head right up and out job is easier than i expected thank god just hope the lifters fix the problem
Trending Topics
The "other" ppl you are referring to are a bit ill-informed. Octane has nothing to do with MDS. Deactivating cylinders to promote fuel mileage, again, has nothing to do with Octane ratings. Octane ratings will have more to do with spark knock or pre-detonation inside the cylinder. But this can also vary by engine load. Neither spark knock nor pre-detonation have anything to do with MDS. Sorry.
As for the OP, to back this up, bad or poor fuel would not affect one cylinder. The same fuel goes to all cylinders so therefore it would affect all cylinders. So fuel quality or Octane is not the issue.
I had the issue of a smooth warm-up and then 1-2 minutes of driving would shake the 2007 Durango with 5.7 (150,000 miles) and create a P1416 code. If I turned the car off, counted to 5, and then restarted it was great for the rest of the day.
I replaced all the lifters, the #6 MDS, camshaft, purge valve, PCM from a wrecker, spark plugs, heads cleaned and planed, moved all injectors and coil pack around, and the P1416 was still there.
Even though the MDS on cyl #6 was a genuine Mopar from the dealer and replaced only the month before, I decided to replace it again under the 24-month Mopar DIY parts warranty. After 3 days the truck is no longer doing what it was and is not creating any codes. Fingers are crossed the problem was a defective new Mopar MDS.
