How to get out of lockout after using wrong transponder key?
Old 09-15-2011, 05:16 PM
JayDee240's Avatar
JayDee240
JayDee240 is offline
Default How to get out of lockout after using wrong transponder key?
Long story... crappy truck... 2006 Dodge Ram ST 4.7l 4x4 QCLB... shorted wiring harness... fried ecm... Got new a new ECM, programmed to VIN number of truck, but I have the wrong transponder key. I'm assuming the previous ECM did not match the vin of the truck, which could have been why the ABS didn't work I suppose. I couldn't check it because it was dead, the scanner wouldn't read it. Anyway, freshly remanufactured ECM, I scanned it, it's programmed to my vin, but my key won't run the truck. It starts, runs for 2 seconds, then shuts off, just like it would if you have a spare key without the chip in it. After 3 or 4 tries, it "locks out", and turning the key will do absolutely nothing, it won't try to start at all. How do I reset the ecm for when i get a new key reprogrammed? The dealership doesn't know how, so I'm in a pretty crappy situation.
Old 09-15-2011, 08:21 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Your dealership is useless, I've known guys had to have dealers replace the PCM and reprogrammed to the original transponder key with the StarScan Tool...
Quick Reply: How to get out of lockout after using wrong transponder key?
