Front diff oil change - DodgeForum.com
Old 09-25-2011, 03:38 PM
djsim1056
djsim1056 is offline
Default Front diff oil change
Have 07' 1500 quad.cab,I do not see a visible fill /dran plug on the front diff, there is a rubber hose however running to top of engine compartment, for breathing I assume. Can always take cover off to drain...leaves me with the question of how to refill.
Old 09-25-2011, 04:56 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
I believe they're all pretty much that way. Back the top bolts off a bit, then start removing the bottom ones.
Refill via the hole in the face of the cover/side of the diff. 1/2" or so below the bottom of the hole is the usual level.
Old 09-25-2011, 07:40 PM
05220713
05220713 is offline
I have the same truck and did not see the fill plug either at first but it was there after a closer inspection. Look on the passenger side of the cover. Little bit harder to see on the front than the back due to limited space.
Old 09-25-2011, 11:05 PM
Caseys-dodge
Caseys-dodge is offline
some of the dif covers have an actual threaded bolt as the fill hole but most of them have just a rubber plug. Clean off the cover and you should see a flat rubber spot about the size of a quarter or bigger, gently pry it out with a screwdriver.
Old 09-26-2011, 09:43 PM
djsim1056
Found it, it was the flat rubber plug just like the rear. Guess I didn't look close enough the first time. Thanks
Old 09-26-2011, 10:12 PM
BadHazard
BadHazard is offline
pretty sure you can add the oil in through that hose, mine is completely capped off, so there is no breathing taking effect. It is really hard to get the bottle inside the hole to fill the diff. You need a pump to transfer it. Or use that hose, thats what I did,..... lol
Old 09-27-2011, 01:43 AM
freestyledude
freestyledude is offline
I need to buy myself a fluid pump for things like this, it would make it a bit less messy. Remember a tube of RTV when you're at the store.
Old 09-27-2011, 09:27 AM
Marklorenzo's Avatar
Marklorenzo
Marklorenzo is offline
Quote:
I have thought about this for awhile on whether or not to buy a small pump to suck fluids out. The shop I work out of, we do this for differentials, I always feel bad doing it on the cars that really need a full service differential cleaning but they don't even offer that at our shop. For my personal truck I think it might be a solid investment. Any thoughts on this?
Old 09-27-2011, 10:09 AM
Caseys-dodge
Quote:
Originally Posted by Marklorenzo View Post
I have thought about this for awhile on whether or not to buy a small pump to suck fluids out.... For my personal truck I think it might be a solid investment. Any thoughts on this?
Right now I have a cheap "hand start" syphon pump that I have used on windshield washer fluid, PS fluid, and brake fluid. It's decent for small jobs but no way would that handle thick gear oil. So I too have been thinking about a small pump. They make some that attach to most handheld drills, but I'm not sure of the viscosity of the fluid it can handle. But since northern tool and harbor freight carry pretty cheap ones I suppose if it doesn't work out so well it's no big lose.
Related Topics
Thread
Forum
Replies
Last Post
RCPete
1st Gen Ram Tech
2
08-23-2015 12:00 PM
SUNBURNTsnype
2nd Gen Dakota
1
07-11-2015 02:39 PM
learningauto
1st Gen Durango
3
07-10-2015 06:24 PM
rickluc
3rd Gen Dakota
1
07-08-2015 10:26 AM
kenb1023
2nd Gen Ram Tech
2
07-06-2015 01:44 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
