2004 dodge ram 2500 hemi oil pressure problems!
Old 11-30-2011, 12:18 PM
chaseboka20's Avatar
chaseboka20
chaseboka20 is offline
Default 2004 dodge ram 2500 hemi oil pressure problems!
Every once in awhile I start my truck and my oil pressure guage says I have no oil, so I shut my truck off and start it again and then its fine. I check my oil every day and its fine. Whats goin on with it?
Old 11-30-2011, 06:08 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Usually it is a bad oil sending unit if there is no engine noise.
Old 11-30-2011, 06:30 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
agreed. oil sending unit right above the oil filter. go to your local auto parts store and pick one up
Old 11-30-2011, 06:35 PM
chaseboka20
Are they hard to replace?
Old 11-30-2011, 06:40 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
no, they just unscrew from the block
Old 11-30-2011, 06:45 PM
chaseboka20
sweet! thank you
Old 12-01-2011, 11:32 AM
Willy McNasty's Avatar
Willy McNasty
Willy McNasty is offline
Thumbs up
Thanks Mr. Weedahoe. I have one on order & should have it installed this evening after work. Should I put any type of sealant on the threads? Teflon ect?
Thanks
Old 12-01-2011, 12:58 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
No thread sealant because the threads provide ground thro the block for the sensor
Old 05-11-2012, 11:58 AM
MikeWilliamson's Avatar
MikeWilliamson
MikeWilliamson is offline
Is there any danger to no replacing this right away? My pressure dropped to zero and the check guages light came on, but no engine noise or check engine light. 2005 Ram 2500 5.7L. Don't want to damage something trying to get home from work and then back to the parts house tomorrow.
Thanks!!
Old 05-11-2012, 11:59 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Only damage is that IF you really are at zero pressure you wont really know it and blow the engine
Quick Reply: 2004 dodge ram 2500 hemi oil pressure problems!
