Dash Brake light and ABS Light
Old 07-10-2020, 10:42 AM
Techster's Avatar
Techster
Techster is offline
Default Dash Brake light and ABS Light
I have a 2003 Dodge Ram 3500 SLT with the Cummins diesel, I am experiencing something that appears to be a loose connection. The Brake light and ABS light comes on simultaneously when I hit a bump or rough patch in the road or when I turn suddenly as avoiding something. I believe it to be a loose connection or maybe even low level of fluid in the differential as one poster stated. Any ideas? I am going to go over all the wiring today and see if I find anything out of the ordinary, I have already checked and topped off the brake fluid reservoir and this didn't solve the problem. Finally, the brakes are fine and I haven't experienced any problems with them not working properly.
Old 07-10-2020, 10:51 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,176 Likes on 2,929 Posts
Quite likely a bad connection somewhere, or, possibly, a worn bearing.... (most likely in front...)
Old 07-10-2020, 11:10 AM
Techster's Avatar
Techster
Techster is offline
I will check that out. You do not think it could be an ABS sensor on the front wheels? Funny you are a blue dragon. My high school mascot was a dragon and our colors were blue and white.
Old 07-10-2020, 02:16 PM
HeyYou is offline
If one of the bearings was getting sloppy, it *might* give an intermittent signal, which would annoy the ABS system.
I got my avatar from a gaming site I am Admin on. I just use it pretty much everywhere.
Old 07-10-2020, 02:18 PM
GRNDPNDR's Avatar
GRNDPNDR
GRNDPNDR is offline
Probably the sensor in the wheel/hub. Same problem for me, the snesor wire was completely broken in half though when the lights decided to stay on
Old 07-16-2020, 06:42 PM
ProStreetDriver's Avatar
ProStreetDriver
ProStreetDriver is offline
Scan the codes and that'll give you an area which circuit is acting up. Could be a bad connection, broken wire, or something else.
Old 07-19-2020, 10:38 AM
GRNDPNDR's Avatar
GRNDPNDR
GRNDPNDR is offline
Oh, to add to this, if you have a scanner that can read SRS codes, or ABS codes (can't remember which now honestly,....gonna say ABS though) it'll tell you exactly.
My Innova 3100j told me "LF sensor"
Old 07-25-2020, 11:48 AM
Techster's Avatar
Techster
Techster is offline
Thanks for all the input. The lower control arms were wore out and so I decided to replace all the front end parts including the wheel bearings with the sensors. So far everything is back to normal no brake lights. Detroit Axle makes a nice kit with all the front end parts except the lower control arms. I used Mevothech for the lower control arms and Timken wheel bearings. Read too many bad reports on Moog lately so I decided against them.
Also, the truck rides a little rough being a one ton. Does anyone think some Bilstein shocks would help the ride? Finally, the truck is approaching 300.000 miles after seeing the front end when would be a good time to replace the wheel bearings in the rear end and drive line?
Old 07-26-2020, 06:46 AM
HeyYou is offline
It's a one ton, so yeah, it IS going to ride rough, especially when not loaded. I discovered that might 3/4 ton ride pretty nice with a thousand pounds of scrap metal in the bed. But, that's not something I would want to do every day.
If the bearings in the rear axle aren't causing any problems, just leave 'em.
Old 07-27-2020, 10:00 AM
Techster's Avatar
Techster
Techster is offline
One of the wheel bearings was rough so I'm pretty sure you nailed it on the brake lights staying on. As far as the ride I haven't replaced the shocks in over five years and that could have something to do with it also. I am going to use the Bilstein shocks this time. The same ones that motor homes use and that should at least improve it somewhat. Thanks again for your insight.
Quick Reply: Dash Brake light and ABS Light
