Cold Air Intakes
That's why I am wondering to be honest. The stock box pulls cold air from the front of the truck, not hot air under the hood.
If I put this AirRaid unit on, that isnt ducted from the front any longer I assume, which means is can move more air, but it will be hot air now.
Is it worth it? On top of that, I would gather I need to replace the piping to the throttle body as well and remove the hemi hat to get the most benefit.
Cold air kits on a dyno will give you around 5HP or less. So little that you likley will not be able to even feel it. Unless you have headers, free flow exhaust and a larger Throttle body soon to be added, i would not worry about the CAI system.
I think alot of this is just hype. The whole CAI is just that. Manufacturers built a billion dollar enterprise from this one part. There are few ways to get a true CAI and the 3" pipe, filter, and shield are not going to give it to you. Only a True hood scoop with a short, insulated intake pipe would work.
What about all the heat passing through the radiator, eminating off the engine, and original temp of the air, does that not heat soak through the walls of the Airaid intake pipe? What about the "cool" air passing through the TB, does it still stay cool? What about inside the cylinders, Is it still cool in there? especially after (600 Rpm idle x 8 cylinders =4800/2=2400 explosions a minute. I really dont think so. The best affect you could get would be in the first 10 minutes of driving, before underhood temps reach max and the air passing through the grill and radiator can keep the temps down.
If you have a CAI with the filter mounted outside the engine bay and do not believe me then I ask you to complete one small experiment:
First,
After the truck has warmed up and idling nicely, open the hood and grab your CAI intake tube near the TB or grab the throttle body itself (as neither of these "create" heat by themselves during normal operation) and tell me it isnt hot. Not hot, well shouldnt it be pretty cold then. The air still has to travel through the TB, intake manifold, past the intake valves, and into the massively hot cylinder.
I know it sounds slanderous. I have been putting CAI's on every car Ive owned for the last 15 years. I just don't believe the reasoning that it actually can deliver "COLD" air.
I will continue to install the CAI, but I will have to agree with Hammer and NV290, and call them MAI (Mass Air Intake). The issue with mostly all actual CAI systems is water, like NV290 said and A snorkel system would work if it was insulated inside the engine bay.
I like the look, the thought, the perception is gives other people when they see it, and mostly, the sound.
First,
on
That's why I've always recommend guys make their own. First off, it's gonna give the same gains any ebay or auto accessory store one is gonna give - unless you drop $500 or more on a true CAI. Secondly it does give a nice personal touch under the hood - and anybody who's payed any attention to either of my vehicles knows I'm into making my own sh*t to add a little bit of distinction as well as functionality. Third - you will see some gains, albeit a small one UNLESS you support it with other mods (headers, ported tb, heads, cam, etc.) where gains can be considerable. Lastly, one will give the exhaust sound a little better note...
I agree with the above on systems where the intake itself is drawing engine compartment air in. But an intake system with a hood scoop OR one that has an intake ahead of or under the radiator would help as well. "Cold" does not have to be by definition 40 degrees (as an example). The goal is getting COOLER air into the induction which can boost horsepower.
Having just installed a gauge yesterday that reads the Computer's IAT, i was able to see my actual inake air temp. It was 60 degrees yesterday outside and yet my IAT was reading 80 degrees. Even on the highway at 70MPH. The reason being is the induction is drawing air in from the engine compartment and the tube from the filter to the engine absorbs heat. So you are drawing in air that is heated from the exhaust manifolds as well from the radiator. Remember, all the cool air that passes through your radiator and takes the heat out of the water is now rushing into your engine compartment. It's HOT under the hood. All of these CAI kits are drawing air from the same place my filter is now, except they have an exposed element (i have the stock airbox) so you can be sure that the it will be picking up even more hot air compared to a stock air box which draws air in through the snorkel near the front fender. Ill bet it's cooler.
And all you need to do is get air from OUTSIDE the engine compartment to make a noticeable difference. It really makes no difference if some heat passes through the intake tubes from the ambient air in the engine compartment. Because that heat will still be much less then if you weere drawing actual air from under the hood. As an example, if like in my case, it was 60 degrees outside and my IAT was 80 since i was drawing air in from the engine compartment. If my inlet was under the bumper, the air would be much cooler then 80. But yes, their would be some increase in temp from the tubes themselves heating up. But still better then engine compartment air directly.
I do agree and the issue seems to stand with only one word: Cold. I do think cold is around 40 or so. Haha, but in this for instance, cold should be as cold as exterior temps +/- 5 degrees. A little better is better than standard, which we all seem to have our eye on, seeing the millions of posts a day on forums about mods.
So given a very rough standard, lets assume the 60 degree day and the 80 degree IAT temp. So you are seeing a 20 degree difference. From the fender of your truck to the IAT and the position of the IAT is relatively close to the TB. So inreality the temps are even higher as they pass through the TB and other components before combustion. This would be pretty close to the factory setup , except you may be pulling a couple more CFM's, which would also lower a couple degrees.
Everybody else not using the stock airbox for heat protection are gonna see higher temps. Probably 30 - 40+ degrees. Much less "Cold" than advertised, either way.
So as a finale, a stock airbox with filter unit is equal to a "CAI" system, unless the system is a "true CAI" with an external element, snorkel, or hood scoop. As I am sure the extra CFM's with a CAI equal out with the added temps that will be pulled in.
How are you viewing the IAT temps? I would like to do some test setups and see what is best, that way I can just do that for every vehicle in the future.
AeroForce Interceptor. I have a thread on it active right now. And tonight i just drove home from work and again saw a 20 degree temp differential between the outside air temp and IAT. That was using my overhead display temp reading and the exterior temp the ECM is reading as well. They were within 3 degrees for the most part.
With the exception of idle, i was around 4-7 but never higher than than 10 degrees difference from my IAT temps to the temp showing on the overhead. Drive was around 35 miles w/ zone speeds of 65/55/40/35
IAT was using my SC3815
The longest idle at the light was about 18+ difference in temp which was a few minutes but i gotta try that again on the drive home.
What intake setup do you have?
Well I am going to do it today. I have your everyday standard CAI from ebay and I am going to see how close to a CAI i can get. Got all the supplies already.
Im thinking Flex aluminum pipe, into a filter housing, more flex aluminum, and insulation wrap for the whole thing. I think I can equal outside temps with this setup. I will take pics and how to if anyone wants. I just need a way to test it.
Im thinking of getting the flashpaq, but the $350 will make me have to wait on the brush guard and lights I want. I think the tuner is a better option, especially since im seeing my mpg fade. Im doing the o2 sensors tomorrow also.
I think one of the best things you could do to help the temp is to insulate the tube going from the air box to the Throttle body. Ill bet that is one of the biggest reasons for the increase in temp. No matter what it's made of, it soaks up heat from the engine and exhaust manifold below it and any air passing through it will be warmed.
Your plan to draw air from a source outside the engine compartment will help a lot. But you will still see a rise if you leave the tube uninsulated. I am going to look at some options and post what i find.
