2wd vs 4wd rear end difference?
Old 05-01-2012, 09:14 PM
areinike's Avatar
areinike
areinike is offline
oh bump stop pads on the axle itself ... gotcha .. I was confused. I had the rubber stops on the frame I had to remove to install air bags, but never did notice I didn't have the landing pads for the stops on my axle. Interesting.
Old 05-02-2012, 09:36 PM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
Default reiterate... pinion angle?
So down to my last question... pinion angle. Wondering if there is any difference in pinion angle since the axles are further from the frame than a 2wd.
Otherwise I think I'm all set to buy my 2wd axle replacement for my 4x4!
Thanks,
Paul
Old 04-17-2018, 11:29 AM
Desire Visser's Avatar
Desire Visser
Desire Visser is offline
Default Rearend?
Originally Posted by TrueDogman
Presently in the process of putting a 2wd rear end into a 4wd truck. Yes, bump stops are missing for the 2 wheeler. However, I have air bags....which eliminate the requirement for bump stops.
If you have any questions, shoot me a PM.
I was wondering if the rearend worked ok? I got a similar situation.
Old 04-17-2018, 11:55 AM
TrueDogman's Avatar
TrueDogman
TrueDogman is offline
Yes. It worked fine.
Old 08-16-2021, 04:11 PM
elmero's Avatar
elmero
elmero is offline
Did you have any issues with it down the road? I’m looking to swap my 2wd with 4wd
Old 08-16-2021, 06:53 PM
TrueDogman's Avatar
TrueDogman
No. Like posted years ago only difference was the bump stop. Ensure you get the gear ratio you want in the replacement differential
Quick Reply: 2wd vs 4wd rear end difference?
