2wd vs 4wd rear end difference?
2004 Dodge Ram 1500 4x4 QC
Local junkyards are telling me that there is a difference between a 4wd and a 2wd rear end (the rear one of course). They don't know what it is, but the "numbers are different".
Is anyone aware of what the difference is? That shortens my list of donors!
Thanks,
Paul
Thanks,
Paul
Dealers have different part numbers between 2wd and 4wd on the empty housing. My LSD clips broke and ground into the bearing support, so I need a good housing.
Must be something different between 2 wd and 4 wd. I can't imagine why it'd be different, but they are somehow different. I'm leery of buying a 2wd version for my 4x4 truck until I know what is different.
Regards,
Paul
Regards,
Paul
No difference as far as fitment goes when your a 2wd installing a 4wd rearend. I dont think it has anything to do with Open or LSD equip either.
The 4wd has bump stops and the 2wd does not. This means you could install a 4wd on a 2wd but not the otherway around unless you fabricated up the bump stops. 2wd's dont need bump stops.
I'd imagine the "tiedowns" for the brake lines might be in a slightly different place, but who cares. Throw a couple of zipties or metal band wraps to hold them securely in place IF thats the case.
I found THIS and it actually looks like the brake lines spot is the same.
I really think the bump stops are the only difference. Maybe cut them off yours and weld them on the new one???
Thanks,
Paul
Paul
www.*********.com/forums/showthread.php?t=265859
dodge talk is starred out (one word)
thats where I took the pics from
Lets try this evasive manuvere that DF cant block/restrict. Click on the first link and scroll to the last post. That is the link I used. http://search.yahoo.com/search;_ylt=...m=EGMB&rd=pref
btw, the 4th one down on the list is the actual thread linked directly into DT. It's 2 pages and on the 2nd page is that link.
4x4 rear end 1st pic
2x4 rear end 2nd pic
Trending Topics
bumpstops are over rated :-)
I looked at my bumpstops, doesn't look like the rubber ever came into contact with them. I don't 4 wheel this truck (at least not yet). Also thinking they're not really doing much, they don't sit much higher than the axle tube. I suppose if it came down really hard *maybe* it'd dimple the tube, but I'm thinking those brackets might be over kill. Either way, if I wanted to add some they'd be an easy fab. Not much point of sawing off the originals.
pinion angle?
Wondering if the spring brackets might be at a different angle, if the 2wd is lower than the 4wd they might do that to optimize and keep the joints as straight as possible.
