Tire Sizes for a 2500HD 4x4
Old 05-27-2012, 04:20 PM
crmcknight's Avatar
crmcknight
crmcknight is offline
Default Tire Sizes for a 2500HD 4x4
Will 35 inch tires fit on a 2500 HD 4x4 with 17 inch rims? If not what's the largest tire size I can use without lifting the truck?
Old 05-27-2012, 04:35 PM
cyclone429's Avatar
cyclone429
cyclone429 is offline
Power wagon is stock with 285 70 17, as for that specfic size in in, that I don't know, I have seen 305 70 17 in on ram 2500 with stock suspensions.
When you up size tires on the stock rims, it will add extra wear on brake pads, ball joints, front u joints, rear u joints, stearing componants and will decrease your trucks towing ratting.
Old 05-27-2012, 10:46 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Old 05-28-2012, 12:40 AM
IamFrank's Avatar
IamFrank
IamFrank is offline
You've got tons of height space but it is the width that can be a problem. If you are cool with the classic cookie-cutter look than you've got room on stock suspension but if you want it meaty and tall then you may want to give it a modest lift.
Old 05-28-2012, 08:39 AM
hillbilli's Avatar
hillbilli
hillbilli is offline
Looks like you will need at least a level kit with 35's.
Nice lights there weedahoe, took me a second to realize you changed pics.
Old 05-28-2012, 09:54 AM
crmcknight's Avatar
crmcknight
Thanks
Old 05-28-2012, 01:39 PM
Rammin It's Avatar
Rammin It
Rammin It is offline
I have 315-70-17's on stock rims. Factory height on the tire says 34.5, but they are actually about 33.25 on the rim. The only problem is they rub the upper control arm at full lock left and right. Installed a 2" lift and they still do it. But they should fit your truck as well.
Old 05-28-2012, 08:26 PM
IamFrank's Avatar
IamFrank
IamFrank is offline
Yup that's what I'm saying. Lots of height room but width is a pain. Wheel spacers can help that but you get that frog look.
Old 10-14-2012, 10:07 PM
20102500black's Avatar
20102500black
20102500black is offline
my question is similar. i have a 2010 2500hd hemi I would like to put bigger tires on once my stock tires ware out. what is the biggest tire i can put on my truck without damaging anything? or hurting hualing capibility? would i be better getting a lift kit? then i might not fit in the garage.. man its a lot to concider.. by the way i cant spell worth a darn..
Old 10-14-2012, 10:09 PM
20102500black
help im new at this.
Quick Reply: Tire Sizes for a 2500HD 4x4
